-   -   Found an engine bigger than Craigs (http://www.clubcobra.com/forums/australian-cobra-club/46322-found-engine-bigger-than-craigs.html)
boxhead 10-15-2003 06:00 AM
I found this yesterday whil checkin out another site.
http://users.tpg.com.au/rwwitt/newdr...dragmania.html
It is apparently about 1200hp with a full cooling system and will tour the car shows doing burnout displays.
Rebel1 10-15-2003 06:53 AM
Now what you gone do that for hey?
Now Craig wont be happy till he beats that number...be like a bear with a sore tooth and Scott will have to start building more pipes and stuff
Sheezzzzz :D :D
750hp 10-15-2003 05:18 PM
Box - Ben's new ute is hopefully going to be at www.powercruise.net Should be a bit of fun to watch!!!
Les - you haven't seen pipes until you've seen Mike Moran's QUAD turbo big block Chev.... http://www.hoon.tk/tech_tips/qtv81.html
:eek: :eek: :eek: :eek: :eek: :eek: :eek:
Probably the most technically advanced Big Block Chev ever built...
justbetter 10-15-2003 07:24 PM
Its not that hard
:3DSMILE: SEE CRAIG ITS NOT THAT HARD TO SAY :3DSMILE:
:D A Big quote from you goes a long way :D
:eek: Probably the most technically advanced Big Block Chev ever built...:eek:
Come on, Come over to the dark side.....
" YOU KNOW YOU WANT TO "%/
;) I'll ask the rest of the crew, im sure the will let you in, just tap you heals togeather and say it three times out loud...
:) Chevy
:D Chevy
:3DSMILE: CHEVY
Cobranut 10-15-2003 11:24 PM
See if you can find anything bigger than this.
http://www.bath.ac.uk/~ccsshb/12cyl/
750hp 10-16-2003 03:58 AM
5,600,00 lb/ft torque :eek: Yeeeehaaaaa!!!!!!! Doing burnouts at max rpm of 102 just wouldn't sound the same though..... Gotta love all those head studs !
Garrett - as soon as silver-plated, nitrogen-filled, aluminium tube O-rings that seal Pro-Stock sourced DRCE cylinder heads that are CNC-prepared by none other than Warren Johnson become standard issue on big block chevs, I'll buy one. Until then, they're still just truck engines :p No, a friend of ine has a 13:1 comp 509 cube BBC in a 4400lb 65 SS Impala. It runs high 10s in street trim with no nitrous, so they most be decent engines...
If I was to build myself a Chev motor, it would be something like this one that's going into an Ultima GTR :
http://www.ultimaclub.com/Images/Own...is+engine1.jpg
justbetter 10-16-2003 04:35 AM
Fair
mate you know some people, any chance i can get me one o dem in the front of me SF.
Gaaaauuuud i'd love it:3DSMILE:
That thing gota go%/
Thanks for the photo keeps me pushing Aussie Mike to get his wheels turning.
So we might one day work on somthing that hopfully will stop.
Garrett;)
