-   -   Chebby and Box (http://www.clubcobra.com/forums/australian-cobra-club/80868-chebby-box.html)
stiffy 07-23-2007 11:47 PM
Chebby and Box
Hey All,
I know someone will be able to assist:3DSMILE:
I require a 6 Litre Chebby and a 6 speed Manual tranny to start the Daytona.
If I cannot get the 6 Litre I would settle for a 5.7 Litre as the location points for Exhaust,engine mounts and so on are the same (So I have been told).
I dont need a working one just one that is complete.
I am still looking for a donor 6 Litre and 6 Speed if you know anyone who has a wreck........:JEKYLHYDE :JEKYLHYDE
STIFFY
sambo 07-24-2007 12:01 AM
Stiffy... I doubt you're the only one looking to get these "Euro 3" engines from a wreck, but good luck all the same.
If you have a spare 10k speak to Chris Tate at World Automotive Surplus Parts (W.A.S.P.) on 0418135211. He does a terrific package deal on the L76 - most things required to start her up, including reflashing of the computer to knock out the security and airbag sensors, alternator, looms, belts, pulleys, etc. These are straight from the production line in Adelaide and come with Holden engine numbers which keep the Vicroads people happy. For a while he was doing the T-56 gearbox for about 3000 plus GST.
Paul
stiffy 07-24-2007 12:27 AM
Sambo,
Just had a lucky call, everything I need for under $15k :D :D Sold I said to the man on the phone.....
STIFFY
Rebel1 07-24-2007 01:30 AM
C'mon stiffy fess up....what did ya buy?. :eek:
sambo 07-24-2007 01:40 AM
Stiffy,
Yeah my quote for everything from fan to rear of gearbox was just under 15k. Forget the factory clutch though, get a Textralia.
stiffy 07-24-2007 01:59 AM
Rebel1,
Complete from head to toe, minus the fuel pump...
L76 with 6 speed.
HAPPY STIFFY
Rebel1 07-24-2007 02:15 AM
Originally Posted by sambo
Stiffy,
Absolutely correct and the Textralia comes with a special flywheel so you wont need the standard one. Same with the internal slave cylinder.
Other bits that have been included in some packages are:
The battery power harness...not required for our cars.
The ECU mount base....not required
Don't buy the holden right hand engine mount bracket unless you are sure the chassis is set up for it. Get the Corvette one from Eagle in Sydney.
Don't get the factory belt unless you are using the holden power steering.
If I think of any more I'll post em later. :)
stiffy 07-24-2007 02:48 AM
Cheers guy's....
The bloke mentioned what you said Rebel1, what is wrong with the STD clutch?
STIFFY
sambo 07-24-2007 02:48 AM
Great info Les. Keep it coming!
Plums 07-24-2007 03:03 AM
The standard clutch will be ok in a Cobra/Daytona due to it's weight, or lack of it.
If you plan on doing some track work though, an upgrade before the engine/box goes in is a good idea.......
Rebel1 07-24-2007 03:06 AM
Originally Posted by stiffy
Cheers guy's....
STIFFY
Best I can advise stiffy is to have a good look at the LS1 forums and search for clutch. Heaps of reading
http://www.ls1.com.au/forum/forumdisplay.php?f=9
