-   -   VDO Tacho (http://www.clubcobra.com/forums/australian-cobra-club/84950-vdo-tacho.html)
Dimi 02-02-2008 06:12 AM
VDO Tacho
Hi all
I am running a Ford Boss 260 using the standard Ford ecu standalone and no other modules,(Bem, Security etc).
Has anyone connected a VDO tacho to a Boss 260 and got it working correctly?????.
Any info or wiring diagrams, adaptors etc would be very much appreciated.
Dimi
sideshow 02-02-2008 03:33 PM
hey dimi
on the ford ecus there is no external wiring thats goes to the tacho alone
its done by serial data
you can try an adapter that runs off the crank or cam sensors
u just have to be careful u dont disrupt one of these signals or engine might start missing at hi revs or something similar
another thing ive heard can be done is remove ecu covers and on the circuit board there is a pin or track that has rpm signal but this might be risky
ive heard it being done never seen it
easiest way is to hook up tacho booster from cam signal but first i would have to see how many triggers are on each
as i think the crank signal is way to many pulses and its prbably not perfect as it has a missing tooth pulse
so cam sensor might be the go
or run a 4 into 1 tacho booster off 4 coils then it has 1 output
WKB 02-02-2008 08:11 PM
Dimi,
People I know that used 4.6 ltr quad cam motors used the ac voltage output from the altenator as a signal source for thier VDO tacho. Their auto electrician installed a wire in altenator before the rectifier diodes for the tacho.
This seemed to work for them and the altenator on the 5.4 ltr motor should be same so it should work.
Warren
