Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-01-2010, 03:08 PM
Gunner's Avatar
Cobra Make, Engine: ERA 707, 446ci FE
  1. Thoroughly lube the cable - use a good silicone-based lube.
  2. Try to pull any sharp bends out by tying the cable to support points.
  3. Get a longer cable if you can so that the bends can be made into fewer and larger radiuses.
  4. When all else fails, go to an electronic speedo...
= Si Opus Quadratum vis, angulos praecidere noli. =
