Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-21-2011, 07:17 AM
RET_COP's Avatar
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
Default Bigger header primaries
Can I buy headers for my B&B Cobra with 1 3/4 primaries ceramic coated to replace my originals of 1 1/2 Primaries?
Lou
Old 08-21-2011, 06:21 PM
boris_thespider's Avatar
Cobra Make, Engine: B&B, 1969 392w, Tremec TKO
Bryan has them.
Old 08-22-2011, 01:24 PM
jbmatth's Avatar
Cobra Make, Engine: B&B 351w
Do you know what the cost would be off the top of your head?
I believe that any man's finest hour, his greatest fulfillment of all he holds dear, is the moment when he has worked his heart out in a good cause and lies exhausted on the field of battle - victorious.
Old 08-22-2011, 06:19 PM
RET_COP's Avatar
Thanks for the reply. I can see that the rear pipe on the driver side is going to be close to the footbox unless the bigger tube header is bent a little different.
Lou
Old 08-22-2011, 07:26 PM
I have the 1-3/4" pipes for my 351w and there's about 7/16" between the corner of the footbox and the header on the driver's side. I asked Barry (when he still worked at B&B) and he said that it would be fine being that close. I still ended up wrapping the header at that spot with header wrap to be on the safe side. I didn't weld my motor mounts until the headers were attached so I was able to push the motor forward as much as possible to get the most clearance.
Mike
Old 08-22-2011, 07:31 PM
I decided to switch to the larger headers before I even took the smaller ones out of the bubble wrap. Since they were still brand new, never even mounted, Bryan let me pay the difference between the two as long as I paid for the shipping. I believe the difference was only about $75.
Mike
