-   B & B Cobra's --- Speak with Bryan Anderson (http://www.clubcobra.com/forums/b-b-cobras-speak-bryan-anderson/)
-   -   Rear bumpers (http://www.clubcobra.com/forums/b-b-cobras-speak-bryan-anderson/124713-rear-bumpers.html)
amsmntparks 12-24-2013 07:38 PM
Rear bumpers
So my B&B is in need of some rear bumpers. Does anyone have pictures of how they're installed? I also need to drill the body holes myself. Anyone have any measurements for locating them?
amsmntparks 12-25-2013 03:49 PM
I actually found some decent pictures of the mounts so I just need to know where to drill the holes now. I'll probably need some way of locating the front holes as well.
Can someone measure from the center line of the tubes to the edge of the frame (front and back)?
lnfletcher 12-26-2013 09:22 AM
Each car is a little different. It depends on how the body was put on and if it centered, etc...
You should be able to mount the inner part temporally and put a small tube of wood or plastic to mark your holes from the inside.
Larry's Home Page
amsmntparks 12-26-2013 09:52 AM
Thanks, those were the same pictures I found to make sense of the rear. Are there any guidelines on where the bumpers should be between the tail lights and trunk lid? What about locating the front?
If there's nothing special to keep in mind I could just get to where it looks about right and go for it.
lnfletcher 01-02-2014 05:24 PM
That's what I did!
