Connector for steering column wiring harness
Did anyone pick up a rounded connector to mate to the stock B&B Steering column harness, or did you just pick up some other type of connector. I am going to be working on this soon and am looking for ideas. If you picked up the mating connector, where did you get it, and what was it from?
I snipped off the connector's plastic casing coming from the column because I could not find a matching connector. Once the plastic casing was revealed, I simply had a bunch of wires with connectors. At the local Auto parts store I found electrical connectors that fit the wires from the column. I then conected each wire individually. A little shring tubing some tape and it seems to work fine.
The steering column is from a mustang II or a pinto. Jim
I went down to the area "pick a part" (junk yard) and bought one. Getting hard to find though.
Steve |
| All times are GMT -7. The time now is 02:51 PM. |
