-   B & B Cobra's --- Speak with Bryan Anderson (http://www.clubcobra.com/forums/b-b-cobras-speak-bryan-anderson/)
-   -   B&B Rear tire Size (http://www.clubcobra.com/forums/b-b-cobras-speak-bryan-anderson/20192-b-b-rear-tire-size.html)
Blake Olson 09-10-2002 01:34 PM
B&B Rear tire Size
Ok, picked up the B&B Turnkey Minus last saturday morning. I gotta change out the back tires....60 series are too tall for me in the rear.
What do you guys recommend? It came with 275/60/15. I'm thinking of going either with 275/50/15's or 295/50/15's.
I'm also thinking of upgrading to Team 3 wheels. What backspacing seems to work on the B&Bs?
blake
shelby bankston 11-03-2002 02:11 PM
just got my turn key min. also its very nice they do good work. i hate to type if you would like to talk call me 5174247941 tecumseh Mi. after 5pm
mkcobra 11-23-2002 07:38 PM
275/50 work good. i you go with the wider tire make sure you have more room in and on the outside of the wheel well. some cars the inner body and frame are close and i may rub. the best thing is to take it in and have them mount one and visual check on the ground . good luck. i will try and use up my 275/60 then drop t the 50 series in the rear.
Jim Werth 11-24-2002 03:58 PM
275/50 will fit in the rear. Wheel offset depends on what rear end you have. Jim
