Aluminum radiators
http://www.clubcobra.com/forums/b-b-cobras-speak-bryan-anderson/80460-aluminum-radiators.html)
| chas427fe |
07-09-2007 06:57 PM |
Aluminum radiators
I know there have been posts earlier about the price of the aluminum radiators but I just received mine on Saturday. I spent most of Sunday swapping the brass one for the aluminum but it was hot and I don't work fast in the heat. All I can say is that it went in like a champ. My only problem was that the lower radiator outlet was slightly larger than old one so I had to go buy a six inch peice of radiator hose. I had to drill the holes and put nut serts in so that I could reuse my old fan. It was well worth the money not to have to chase around getting one fabricated. Thank you Karen and Barry for getting this done for me. Chas
| chas427fe |
07-09-2007 07:00 PM |
PS I was able to run in my garage for 15 minutes and the temperature never went over 85 degrees C (185 F). Chas
| MacGyver |
07-09-2007 08:50 PM |
How much lighter is the aluminum over the brass?
| chas427fe |
07-10-2007 07:00 PM |
I don't know. The aluminum radiator plus the packing was 24 lbs. I don't have a scale to compare the difference. Chas
| Karl Bebout |
07-10-2007 07:38 PM |
I weighed both my new aluminum radiator and the custom brass one I took out and I saved 17#s. I'd read a fairly extensive report before the change out that made the contension that the aluminum would make very little difference in cooling. I did it since my old radiator was leaking and I wanted to save some weight off the nose. Just my experience.
| All times are GMT -7. The time now is 01:10 PM. |
