B and B Front Inner Fenders
When I picked up my Roadster kit from B and B the end of May I asked Bryan if the front inner fenders are to be glassed in. He said he intended for them to be able to be taken out if you needed to get to the master cylinder.
After traveling 1250 miles to get the car home I noticed that parts of the inner panels were rubbing against the body pretty good from vibration. I am thinking it might be better to glass those in. Any opinions on glassing those in vs. not. Wayne |
Glassed mine in.Then I sprayed bedliner over it. Never thought twice about it. Jim
I use a rubber gasket on the edge like that on a ford truck door. It seals it and keeps it from rubbing. I plan on replacing the fiberglass units with aluminium.
Thanks guys.
Wayne |
| All times are GMT -7. The time now is 07:52 AM. |
