-   BackDraft Racing --- (http://www.clubcobra.com/forums/backdraft-racing/)
-   -   Stearing rack play (http://www.clubcobra.com/forums/backdraft-racing/108861-stearing-rack-play.html)
Rich_ACC 01-28-2011 02:25 PM
Stearing rack play
I have noticed a bit of play in the stearing:( after inspection it seems to be in the rack itself not the tie rod ends. since not really fond of the play trying to make a discision to rebuild or replace rack any thoughts.
Rich
Cashburn 01-28-2011 06:02 PM
Is it the rack or the joints in the steering shaft / linkage?
JUS BIT 01-28-2011 09:11 PM
I agree with Jay. It could also be the shaft linkage. Lift the front end, try and move each wheel left/right and up/down. That will help you determine if the tie rods are moving. You kinda have to have someone do this while you look at the play on the tie rods. Check the linkage and see if it moves when the tires are on the ground. Sometimes the lower bolt to the rack gets loose. Loosen the 13mm nut first, then tighten the allen key, and then retighten the 13 mm nut. Also check to see if the pillow blocks that hold the rack in place are tight. If all good, than it's in the rack. I would replace it.
Bests, James
Rich_ACC 01-31-2011 03:24 PM
Thanks guy's for the advise. I will check it tonight and get back with what I find.
Rich
