-   BackDraft Racing --- (http://www.clubcobra.com/forums/backdraft-racing/)
-   -   winsheild washers (http://www.clubcobra.com/forums/backdraft-racing/51152-winsheild-washers.html)
thunder1 03-02-2004 02:43 PM
winsheild washers
anyboby know where the control for the windsheild washer are they said it was under the dash by wiper switch which is push pull but can't find it. anybody with a backdraft can they tell me were there are.
not a big deal but the tank and pump are in the car and who knows i might like to use them. car 84
tfarhood 03-02-2004 04:35 PM
mine is a push button next to the horn button.
Boudy 03-07-2004 05:39 PM
Only recently, the switch we used went out of production. That switch activated the washer fluid when turned and wipers when pulled. Well, with the new switch, there is a momentary button mounted next to or under the switch itself. If your car is missing this button, contact Reg.
Boudy
lomdel 01-29-2020 11:29 AM
Reviving very old thread. The new Backdrafts’ wiper pull/push switch have a twist action also which I assume is for the washer pump. Any comments/instructions how to connect a washer pump to that switch, please? https://www.iconicparts.com/wiper-switch-knob
spdbrake 01-29-2020 12:04 PM
Lots questions I have....
1. Does you pump work but is currently wired to another switch?
2. Does your switch look like this?
3. If so does the molex connector have 4 wires installed on the car side? (like the switch side does)?
Assuming the above are yes. You may have a failed pump since the BDR folks should have wired that from the factory.
Turn the key on. turn on the ign key. Using a meter set at VDC back pin the connector one at a time. One should show 12vdc which is the feed+.
(Ensure the black lead of the meter is connected to a chassis ground)
Turn the wipers to Low, now you should see 12vdc on two pins feed+ will have power and power line pin to the motor.
Turn the wipers to High the feed+ will have power along with a different pin to the motor.
Twist the knob and you should have 12vdc on the remaining pin. That is the pump feed power.
If all four molex connector wires are installed on the (car side see #3)
is the wire color on the pump feed power match the wire going into the pump?
If yes check for 12vdc on the that wire when you twist the knob. If its good check for a good ground.
lomdel 01-29-2020 10:51 PM
I do not have a washer pump system at the moment, but I am planning the installation of a washer kit ( https://www.europaspares.com/mechani...-capacity.html ). I do not need it, I just want to prove to myself that I can and the single centre mounted double nozzle looks good and authentic.
My Backdraft's switch looks exactly like that, but with a billet knob.
All the wires are connected to the connector.
Based on your feedback, I will determine which pin should feed the pump and connect it accordingly, thanx.
