-   BackDraft Racing --- (http://www.clubcobra.com/forums/backdraft-racing/)
-   -   Oil Cooler (http://www.clubcobra.com/forums/backdraft-racing/62293-oil-cooler.html)
jeffko 03-08-2005 04:46 AM
Oil Cooler
What size of oil cooler and plumbing has anyone used?
Cashburn 03-08-2005 08:44 PM
Don't know the size off hand but the cooler that Reg sells is the best fit and the AN lines are 6 or 8.
CSCHWER 03-09-2005 05:23 AM
Finish Line can make a shroud that fits pretty well.
Chet
RodW 03-09-2005 06:40 AM
I purchased cooler and shroud from Finshline as well. Fits great. Rod
tony martin 03-09-2005 11:13 AM
OIL COOLER
TALK TO REG
NEW KIT COMING OUT FROM THE FACTORY.
REGARDS
BRIAN@DBR 03-09-2005 01:41 PM
Correction... need to run 10 or 12AN.
Trueoo7 03-09-2005 07:07 PM
Rod W
Do you remember what you paid for that combo? Does Reg have a price worked out yet.
RodW 03-09-2005 08:30 PM
Trueoo7
It wasn't a combo. I paid $135 for the cooler and $125 for the shroud from Finishline. Had Robert at Keith Kraft do the install.
Rod
MrMagoo 03-10-2005 03:49 AM
I got the mocal and shroud from finish line. The mocal is 10AN. Some folks say that you really should go 12AN to ensure the best flow, others say 10AN is adequate. It's winter here in CT and my car hasn't come off the blocks yet so I can't say for sure whether or not 10AN was the right choice, but I suspect it will be fine for the street.
I am running a small block, maybe a monster engine like a 427 or 460 needs the larger diameter?
jeffko 03-10-2005 07:29 PM
Mocal at Finish Line is good quality for a reasonable price. However, you are better of getting the fittings and hose at Summit. The shroud at Finish Line also looks very nice and have seen a few pics of cars with it installed. Looks good and the price is now $75. From what I have learned, Magoo nailed it about line size.
Anyone have a lead for the inline thermostat?
Trueoo7 03-10-2005 07:34 PM
Mr Magoo
Did you install yourself (difficulty factor, much bending and tweaking to fit a BDR?) How does it look?
True
MrMagoo 03-11-2005 04:20 AM
Trueoo7 :
I am not the sharpest wrench in the toolbox but I managed to install the cooler and shroud pretty satisfactorily. The shroud required some snipping to get it to fit in my venom (similar to your BDR I presume). It took me about 6 hours to install the cooler itself, another twelve or so to do the hoses and fittings.
I had to install a remote oil filter due to clearance problems at the filter. And of course I did a thermostat too.
I would say the key thing is to take your time, and plan everything out, as far as where you need to run your hoses, where you want to mount your thermostat, etc. You need to have a good idea of how to route the hoses when you order your hose end fittings to get the right number of elbows, straights, etc.
Make sure you plumb the thing correctly and dont cross the hoses!
I had to learn how to do Aeroquip reusable fittings and braided hose, which was fun. Other than that the skills required seem pretty basic.
I think then end result looks pretty good. I'll send you some pics if you like.
Good Luck.
BRIAN@DBR 03-12-2005 05:50 PM
Mocal Cooler has 10 AN fittings welded on, Trueoo7 We have cooler and shroud in stock for a BDR if interested.
brian@www.vintage-motorsports.com
