Old 09-11-2006, 11:13 PM
Cobra Make, Engine: Backdraft #486 402r This is my 2nd backdraft.
Default Is there an owners manuel available for this thing?
Whoever put together backdraft #182 must have had a brown mushy substance for brains. The motor has no dipstick. The wiring genius wired it so when you turn the key off the motor will not turn off!! Unless you turn the lights off????? But since I would kind of like to have the electric components work like they should it would help if I had a schematic for the electric. I also would find it a bit less attractive to the local police if the tail light sockets would actually hold bulbs. My final ***** tonight involves the stem coming out of the radiator overflow tank leaking at the cap neck. I guess I need to get a new overflow tank if someone can steer me in the right direction.
Paul
P.S. This SOB is fun as hell to drive!!
I have been corrupted by perfume and gasoline!!
Old 09-12-2006, 03:07 AM
BUCKEYE COBRA's Avatar
Cobra Make, Engine: Backdraft #20 302 T5
Paul,
PM me with your email address. I can send you one.
Old 09-12-2006, 07:23 AM
Cashburn's Avatar
Backdraft Racing Dealer
Also let me know if you need a better wiring schematic. The manual PDF does not have a very clear diagram.
On the leaking expansion tank, the best thing is to take it to a radiator shop... they can weld it and then pressure test to ensure no further leaks.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 09-14-2006, 08:22 PM
Thanks buckeye and cashburn.
Paul
Old 11-27-2017, 01:16 PM
Hello cashburn!
Would be glad to get a good wiring schematic of a backdraft cobra!
Old 11-27-2017, 02:09 PM
Cashburn's Avatar
Originally Posted by Pastormajorquin View Post
Hello cashburn!
This post was from 11 years ago. The manual now has a clearer diagram. Do you have the manual?
VINTAGE MOTORSPORTS
Old 11-27-2017, 06:48 PM
BDR0572's Avatar
Cobra Make, Engine: BDR, Roush 402R
https://db.tt/ZzxWCw9oR6
Try this wiring diagram I have 572 and it worked great
Old 11-27-2017, 08:34 PM
FUNFER2's Avatar
"you turn the key off the motor will not turn off!!, Unless you turn the lights off????
Well, look at it as a comical way, it's funny as Hell !
You'll get it all figured out soon !
Kevin
