-   BackDraft Racing --- (http://www.clubcobra.com/forums/backdraft-racing/)
-   -   Track Alignment (http://www.clubcobra.com/forums/backdraft-racing/73515-track-alignment.html)
Mac VABCH 10-09-2006 08:22 AM
Track Alignment
Does anyone have track alignment specs . I am going to an open track event at VIR next week end...Thanks Mac
Anthony 10-09-2006 10:35 AM
Contact your dealer, I would think either he would know, or know of somebody that does.
Alot of people like front 1/8" toe out, - 1/2 camber, + 4 caster,
rear 1/8" toe in, - 1/2 camber.
Badger 10-09-2006 11:35 AM
It's not just the intial setting that counts, but the bump-steer in the FULL RANGE of travel that's important. Start with ride height. It takes a good DAY to scale and string the car and then verify bump steer and correct. Badger
tony martin 10-09-2006 12:27 PM
Wa
Mac,
Race Track Set Up For Backdraft Roadster
Front
Lower Frt To Get -2 Degree Camber
Set Frt Toe In 1mm Each Side 2mm Total Toe In.
Rear
Set Rear Rt Ht To Have 1 Inch Measured On Chassis Higher At Rear Than The Frt.
Set Camber -1 1/2 To - 2 Degree Camber
Set Toe In 1 Mm Total
Start At 1.6 Bar Tire Pressure,cold, All Round.(road Rubber).
Should Build Up To Approx 2.2 Hot
Recomend U Get A Set Of Race Springs From Reg.
Sock It To Them!!:mecool:
Drive Safely,and Have Fun,;)
Regards,:d
