-   BackDraft Racing --- (http://www.clubcobra.com/forums/backdraft-racing/)
-   -   Small Oil Leak in the Oil Cooler (http://www.clubcobra.com/forums/backdraft-racing/75227-small-oil-leak-oil-cooler.html)
Dinobyte 12-16-2006 02:27 PM
I have developed a small oil leak in the oil cooler and was wondering if anyone else with BDR's has had similar leaks? I does not appear to be the inbound or outbound fittings. I also checked to see if there were any dings in the front of the cooler that would indicate a debris strike and none were found.
:confused:
I will have to probably pull the cooler, but wanted to query you guys to see if anyone had seen this before.
Thanks
Michael
Cashburn 12-16-2006 02:55 PM
Michael,
Can you post a pic? Might help narrow the leak source down. The cooler is a Mocal, direct from Finishline. I sent you an email as well.
