Old 06-03-2007, 06:09 AM
Default Metal Shavings in Oil
Doing my first 500 mile oil change today on my PE 351W. I have metal shavings on the magnetic drain plug and in the oil pan.
Is this cause for major alarm (engine is getting ready to let go) or is this "normal" for a newly built engine on the first oil change?
Oil pressure and temp, water temp, etc, have all been in the normal range and hasn't been over 4000 RPM during the break in period.
Old 06-03-2007, 06:11 AM
Shavings or ring dust? Can you post a picture? Steel? Bronze?
Engines should break in, but "shavings" are not good at all.
Old 06-03-2007, 06:46 AM
Woodz428's Avatar
I would pull the dist. and inspect the gear as well as the gear on the cam. There have been at least a half dozen of these type engines(Ford SB) that I have seen in the last 6 mos. experience cam/dist. failures because of a mis-match of gears. My recollection is that they were using a steel gear on a cast roller cam core that had been ground to new specs. They were all from the same engine builder as yours as well.
WDZ
Old 06-03-2007, 07:10 AM
Default Pictures
Not sure how these will look - it is definitely not "dust".
Old 06-03-2007, 07:15 AM
Pictures are small....are those floating on top of the oil?
That is definitely not normal. I would contact the engine builder.
Do they look like steel or are they gold colored?
If you want to do a little investigating before your engine builder steps in, you can pull the dizzy like Woodz recommended and look around. Also, pull the valve covers and see if anything looks amiss.
Old 06-03-2007, 08:20 AM
They look like steel - the pics are of them on the oil drain pan. I will contact Jay and PE to see how they want to handle this.
Old 06-03-2007, 08:49 AM
Cashburn's Avatar
Backdraft Racing Dealer
What's up with the oil filter? Looks like it was beaten around a bit?
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 06-03-2007, 09:14 AM
Woodz428's Avatar
Originally Posted by rngnkr
They look like steel - .
A quick pass with a magnet will tell you for certain.
WDZ
Old 06-03-2007, 09:25 AM
double ugly's Avatar
[quote=rngnkr]Doing my first 500 mile oil change today on my PE 351W. I have metal shavings on the magnetic drain plug and in the oil pan.
Must be steel.
double ugly
Old 06-03-2007, 11:42 AM
lineslinger's Avatar
Attachment 12857
Attachment 12858
No its not dust and that is way too much stray metal to be laying around loose in your oil pan. Shavings that size indicate a growing problem somewhere in the guts of your motor, figure it out now before it gets more expensive.
Old 06-09-2007, 06:43 AM
Default Hopefully good news!
Finally got back from a week long business trip to D.C. last night - reminded me why we moved away from there!
Was thinking about my metal shavings all week! Went into the garage first thing this morning and cut off the top off the oil filter and pulled out the element. Checked it top to bottom, inside and out, between every fold - nothing in there but oil!
I am embarrassed to say this, but I think some of the stuff I saw in the top of the drain pan was possibly little flecks of paint that came off of the oil filter as I was wrestling with it to get it off. There was some metal there (and on the magnetic drain plug), but most likely not nearly as much as I initially thought.
My oil pressure is running 3 to 4 bars on a 5 bar scale, and my oil temp is completely normal. Talked to Eric at PE this morning - told him what I found. He said the pressure and temp are the indicators I need to keep an eye on. Pending further changes, I will probably change the oil again in a few hundred miles and see what, if anything, is in there.
Old 06-09-2007, 11:38 AM
ROUSHAC's Avatar
Either a very good call, or a lucky guess, but right on.
Dave
Old 06-09-2007, 12:37 PM
RedCSX1's Avatar
All the more reason to run a pure power oil filter. Depending on how well the builder did cleaning the motor during assembly you will see some metal as well as gasket material in the oil. Hopefully no brass.
First oil change after the head job on my 482 I saw some aluminum as well as gasket material which the stainless screen of the pure power oil filter trapped. I then cleaned the filter out after the Cobra Bash where I did open track and the filter was much cleaner than the first oil change.
Morgan LeBlanc
Fresno CA
Old 06-09-2007, 12:46 PM
Cashburn's Avatar
Mike had sent me the larger version of the photos and I did look at it closely... I did initially think it was all from the filter but errred on the side of caution until we dug a little deeper.
Not an "I told you so..." moment at all
VINTAGE MOTORSPORTS
