-   BackDraft Racing --- (http://www.clubcobra.com/forums/backdraft-racing/)
-   -   brake part help (http://www.clubcobra.com/forums/backdraft-racing/91031-brake-part-help.html)
rocket7171 09-06-2008 05:52 AM
brake part help
I'm having a problem with my e-brake coming apart in right side rear rotor. The backing plate won't keep hold of retainer and drum pads for e-brake come loose. I've bent slot for retainer three times but it continues to pull back out and releasing shoes. I need to know model and year of backing plate so I can get one from BMW. I've ordered wrong part once and would like to get it right next time. For now I was able to get a bolt and lock nut through hole and still able to keep spring tenison correct on retainer hole but would like to fix it right.
Vintage thought it maybe a 95 325i. Way too big.
Tony, Reg Some help here?
thanks
tom
#188
uncltodd 09-08-2008 03:14 PM
E-Brake? A bitter post from UT.
What E-Brake?
Build # 139.
August, 2004.
Cashburn 09-08-2008 05:10 PM
I'm trying to visualize the "backing plate" we are talking about. I believe if it is the backing plate I am now thinking of it as a part that is modified by BDR at the factory and now they are even cutting their own. You might get a quick response up the chain at the backdraftboys.com site.
Blittleton 09-13-2008 05:10 AM
thanks
tom
#188
Tom,
The bolt and lock nut is the way Backdraft does theirs now. They make a new plate of the dust shield. But I did find an place for you to get one of the original type of dust shield.
http://data.bmrparts.com/bmwparts/18721441930006U.html
this will need to be slightly modified to fit and limit noise.
Bill
