Need head checked
Can anyone recommend a shop in the bay area that can pressure check, etc my aluminum head? I have water in my oil and I suspect one of my heads.
Thanks, Mike |
Mike. Are you referring to doing this work with the head off the car, or doing a compression check with the head in place or doing a radiator pressure check? If you have water in the oil you may have a bad head gasket or intake gasket. Maybe the head is warped due to overheating??
Zoom,
I have the head off the car. I did get a recomendation of a place in Livermore to have the head checked out, pressure checked and straightness. I am wondering if it may just be the head gasket? Visual inspection of the head looks ok. I'll bring it in to be sure. I am also going to re-ring the pistons due to lots of oil burning and blow by. Mike |
| All times are GMT -7. The time now is 08:24 AM. |
