-   Bay Area Cobra Club (http://www.clubcobra.com/forums/bay-area-cobra-club/)
-   -   Transmission Fluid Type (http://www.clubcobra.com/forums/bay-area-cobra-club/88016-transmission-fluid-type.html)
LENSJADE 05-31-2008 10:45 AM
What Is Used In The Tremic 5 Spd Transmission Automatic Trans Fluid Or 90 Weight? Have Superformance # 1350 Any Help Would Be Helpfull
Mac VABCH 05-31-2008 10:53 AM
fluid
GM Syncromesh or ATF. GM Syncromesh I like better ... Mac
Bob In Ct 05-31-2008 04:49 PM
I'm using Redline MTL in my Tremec with no problems. GM Syncromesh is the recommended lubricant. Remember, heavier is not always better.
Bob
vector1 05-31-2008 05:34 PM
standard sent a tko600 with amsoil manual synchromesh 5w30.
Greg tripp 05-31-2008 08:38 PM
Royal Purple synchromax... Great stuff!
scootter 05-31-2008 10:23 PM
GM syncromesh is what I use. Careful when you pull the plug, it comes out like diesel. So have a big pan and make sure its far enough out.
Scott
bret a ewing 06-02-2008 09:39 AM
Mobil 1 synthetic ATF.
Monster 06-02-2008 10:24 AM
Redline MTL
LENSJADE 06-04-2008 06:14 AM
Thanks Everyone For The Information
Len
Got the Bug 06-04-2008 08:07 AM
What's a good rule of thumb for miles and/or time before you need to replace the trans oil? How many miles before you should change the oil in the rear-end?
Thanks.
LENSJADE 06-04-2008 09:37 AM
Should Do Both At The Same Time Both Have Equil Time And Wear
Len
donraye 06-24-2008 05:34 PM
Hi All, I'm not sure the best place to post thing yet as I am still learning about the various forums and what to post where, etc. But since this one is talking about transmission fluids I need to know what to use in my T5 "Z" spec. I just got this car and know nothing yet about what I should be using for the T5 or what oil is best in the 351 425HP engine either. I was thinking to use Mobil 1 or Castrol Synthetic in the 351. Is that OK or are there better choices out there I do not know about? I just bought an oil cooler that I am planning to install in a week or so, so I will be needing to make an oil choice by then. The car is a weekend warior but I do drive pretty hard when I can get awy with it. Any recomemdation?
Also: any one have any recomendations on a good shop for taking the Cobra in the North Bay/ Sonoma county area? Both for engine/mechanical and body/chassis work.
Would love to get a recomendation or two!
Don
