Switching Speedos
DV, I am going to replace the 120 MPH VDO electronic speedometer with a Kirkham reversing 180 MPH unit. Do you have a schematic or layout of the std VDO plug ins or any suggestions as to an easy way to do this? They are both 3 /38" units so the size will be the same.
Jim Stern |
Jim,
I'm not familiar with Toms Reverse gauge. Being both (?) are electric Tom should have the right Hall Sensor to use. swap shouldn't be a problem. Mechanical, you will ned a convertor from Tom so the cable is reversing its normal direction. Shouldn't be a problem at all, just money! |
DV,
Thanks for the quick comeback. Both Speedo's are electronic. I was wondering about the electrical side of the hookup. I received what appears to be a pickup with the Kirkham speedo. I was wondering if the VDO pickup and the Kirkham run the same. I can see me really screwing this up:JEKYLHYDE. Jim |
| All times are GMT -7. The time now is 11:52 AM. |
