Part number / Rear Lower arm Bushing ?????
Hello I am in need of a part number or the exact type of bushings for the rear lower trailing arm bushings ? If any body knows please share .....Someone said it is a chevy part ????
Thanks :o Marty L |
marty, isn't that a 9" rear in the car? take a picture of the arm....
You know what should be done? Start a part thread and list what the part is, what vehicle it is from and the part number. Maybe make it a "sticky" so it will be easy to find and search through. Maybe make sub threads so it can be listed by body, suspension, ect.
Edit: Might be best in the social group area so it does not clog up the regular forum. Don't know if it can be done or not though. |
93 cr 8.5 stock cr lower rear trailing arm bushings
I will take some pictures soon. The car is a 93 CR with the stock lower trailing arms that most of there cars had with the 8.5 diff. The arms are shorter than mustang 2 arms by 3 inches.They measure about 14 inches hole to hole and are unique and built by Classic Roadster Inc For there Cobras. Any information is helpful. I have a hard time believing nobody around here has replaced most all of the bushings after all Classic Roadster closed in 2000 from what I herd. That would make all the rubber in the newest ones 13 years old and saggy with play just from sitting.
Looking forward to the magic answer..:JEKYLHYDE Marty |
If you don't get the "magic answer" from someone, take a look at NAPA 274-6542. As I recall this is what I used, but I think this is the one that had a slightly larger ID so I had to drill out the mounting brackets and use a larger bolt.
MC |
Thank you for all your info. The NAPA 274-6542 part number was right on. The Cr is now much inproved as the old bushings were toast very worn with side to side play.....The Magic answer has been found....Thank You...:)
| All times are GMT -7. The time now is 06:39 AM. |
