Side Vents
http://www.clubcobra.com/forums/classic-roadsters-ii/137230-side-vents.html)
| nodari |
09-18-2016 11:59 AM |
Side Vents
Hoping someone has an extra side vent laying around or set. From what I can tell CR's are a bit larger than the replacements found online. Any input would be greatly appreciated!
| studebaker53 |
09-21-2016 05:06 PM |
I'm with Nodari..........I could use a set also for my classic roadster.
| razerwire |
09-22-2016 02:19 PM |
Could you bend some aluminum flat stock into ninety degree angle and make it big enough to cover hole and be glassed to body with sheet metal screws to hold angle and vent together, that way you could take smaller vent out later if you needed to. Mock up to cardboard cutout the size of car first to see if flat alum showing would look ok. Could glass hole smaller on body and touch up paint? fwiw
| All times are GMT -7. The time now is 01:30 PM. |
