-   -   Interior Door Panel Replacement (http://www.clubcobra.com/forums/classic-roadsters-ii/146894-interior-door-panel-replacement.html)
ATXCobra 05-11-2023 10:06 AM
Has anyone had to replace the door panel on the passenger side in their CR? Mine is looking a bit worn out. I'm wondering if a standard panel will fit or if the CR cars have longer doors with the extra length? I found these at Shell Valley but when I contacted them, they were pretty sure they wouldn't fit.
https://www.shellvalley.com/index.cf...rod/prd111.htm
letsboogie351 05-11-2023 02:39 PM
Go and see your local motor trimmer. I'm sure he/she could help you. Either make a new door card or re trim both existing.
MaSnaka 05-15-2023 03:42 PM
Upholstery shop should be able to make you something similar. I doubt those SV units would fit. I need new ones too.
John
Chicagowil 05-16-2023 02:50 PM
The only other door car even close is on an Excaliber- but still different.
Do you have the plastic style door card base? It would be pretty easy to have a car/RV/Boat upholstery shop redo the door cards.
I just installed my cards last week. My car is a CR1. It has the plastic base with a thin sheet of foam and the skin over that. The holes for the plastic insert style clips had never been drilled. That was the hardest part.
I also added the leather door stops that FFR sells for their Roadster.
I had my dash recovered last month- it was $500. She had to clean up the fiberglass a bit more after I removed the cover. She added a thin foam under the black covering. I think it turned out nice.
I should get the dash installed this week. Just finished the carpet today. And then the seats go in.
Chicagowil 05-17-2023 03:34 PM
Here are a few shots of the door cards & seats installed as well as the carpet.
The carpet & seat colors came with the kit.
I was very reluctant to use the carpet until I saw the recent AC sold in the UK came with this same color!
And, it somehow works OK with the Viking Blue.
If I get tired of it, I can take them out to be redone easily. As I stated before, I already had the dash recovered in black.
http://www.clubcobra.com/forums/pict...=20853&thumb=1
http://www.clubcobra.com/forums/pict...=20850&thumb=1 http://www.clubcobra.com/forums/pict...=20852&thumb=1 http://www.clubcobra.com/forums/pict...=20836&thumb=1
