Old 08-14-2002, 09:48 AM
Curt C.'s Avatar
Default Mustang II Master Cylinder + Rear Versailles brakes = little rear brakes
Hey Guys. DV I hope you can help me here. I have a CR with Wilwood 4 piston calipers in front and a 9 inch ford with disc brakes out of a Versailles. Car stops ok, but bias is way too high towards the front. The rears are hardly getting any heat in them. Is the power brake booster and master cylinder from the mustang II not compatible with rear disc brakes? I could plumb a proportioning valve in the front brakes, but this would just be a band aid. Any ideas?
Curt
Old 08-14-2002, 10:21 AM
Rick Parker's Avatar
cURT: JUST A THOUGHT....MUSTANG II HAD REAR DRUMS AND WAS LIGHTER THAN GRANADA/VERSALLES WITH DISC REARS. THE VACUUM BOOSTER ON THE GRANADA/VERSALLES MAY HAVE BEEN LARGER DIAMETER TO EFFECT HIGHER LINE PRESSURE FOR REAR DISCS(?)
RICK
Old 08-14-2002, 03:09 PM
dscott's Avatar
I'm sure the Mustang II master is to small for the rear brakes. I would go to a Corvette or Mustang GT master with equal size reservoirs. You may need to install a prop valve in the rear to reduce the pressure after the new master. I use a NAPA # 36367 master. You will need to elongate the mounting holes to get it to fit the Mustang II booster. You will also need to adjust the rod between the booster and master, the tip does screw in and out for adjustment. You should have 1/16" between the 2. I usually adjust the rod so it contacts the master when installed then back the rod off.
Don
Old 08-14-2002, 03:43 PM
Double Venom's Avatar
Why repeat what Don says?
Says it all!
DV
Old 08-15-2002, 10:13 AM
Curt C.'s Avatar
Don Scott, You the Man... So the Napa Master, is that a GT or a Vette master? Also, can you elaborate on the elongation comment? I need longer bolts, or drill holes deeper? Thanks a lot, sounds like I will have some real braking rather quick.
Curt
Old 08-16-2002, 08:13 AM
dscott's Avatar
Sorry, The NAPA # is the Vette. The mounting holes are elongated to each side of the master. Basically you are making the holes look like a slot. I use a small die grinder.
Don
Old 08-22-2002, 10:01 PM
Curt C.'s Avatar
OK Gentlemen, I purchased the corvette MC from Napa (36367). Which compartment goes to the front brakes / rear brakes? The front part of the MC (furthest from the booster) appears to have a little more capacity than the rear. Also, the MC came with a large black nipple type seal. How does this piece go onto the MC or booster? Also, what about the brake pressure differential control valve? I have no clue what type is in the car. Could this be causing the problem as well? Should I just replace this piece while I am doing the MC? If so which one should I get?
Old 08-23-2002, 05:32 AM
Curt,
On the GM master the front bowl is for the front brakes, (Ford is just the opposite).
I eliminate the boot that you are referring to, and as the "differential valve or porportioning vlave, we simply use an adjustable valve, (Wildwood available from Jegs for $49.00)
We normally come out of the rear bowl, to the fire wall, up high, to the valve, then to the rear brakes. Simple clean and easily accessible.
See if Don concurs.
DV
Old 08-23-2002, 07:50 AM
dscott's Avatar
Yep, I agree!
Don
Old 09-03-2002, 10:45 PM
Curt C.'s Avatar
Gentlemen,
I works...Works very well. Cant wait to get back on the track. I can now go a lot faster because the car will brake properly. Thanks for the help.
Curt
Old 09-04-2002, 01:04 AM
Post Queston? For DV or Dscott.
On the MustangII MC which bowl is for the front and which is for the rear? (The small bowl and the large bowl).
Thanks.
Snake.
Old 09-04-2002, 05:53 AM
Snake,
Ford... Front bowl goes to the rear, rear bowl goes to the front.
DV
Old 09-04-2002, 10:37 PM
Post DV
Ok...let me get this right....the small bowl is for the rear and the larger bowl is for the front.
Snake.
Old 09-05-2002, 09:55 PM
Curt C.'s Avatar
Steve,
You are correct with respect to the Ford Mustang II MC. The vette mc I installed is reverse
Old 09-10-2002, 01:09 PM
Don,
I was cross referencing your Napa number 36367 with A1 Cardone and Bendix numbers at Checker. That Napa number comes back as a master cylinder for manual brakes. They listed some different part numbers for 1976 Corvette master cylinders for power brakes that cross reference back to a Napa #39018. The Napa website has the 36367 listed for manual and the 39018 for power too. I was doing it on the computer so I can't see what any differences are. Just wondering if there were reasons why you use the manual Corvette master with the MII booster instead of the power Corvette master.
Also, Checker has the remanufactured A1 Cardone and Bendix Corvette master cylinders for $15 to $30 with $5 to $10 core charges. You can find them at www.partsamerica.com. A lot cheaper than the Napa one For $90, but maybe comparatively the're junk. Anybody used any of the remanufactured ones with good luck??
Wade
Old 09-11-2002, 08:14 AM
dscott's Avatar
I never looked at the application for the master. I just found the one I wanted in the book and used it. Most of the manual brake masters have a rod attached to go from the master to the pedal. The power brake booster has this rod already. The 36367 master does not have the rod and it matches the Mustang II booster with a little modification. It shouldn't matter which master is used if the attachment is the same.
Don
