01-11-2003, 07:05 AM
Mi
Jack,
Is your fuse block ...long with glass fuzes? This is a type we have seen many "builders" use in the dark ages of kit cars. Bottom line, they well, they simply suck! If that is the case it is NOT a CR's harness.
Second thing, if you have a neutral safety switch, how or why did the car..."I just had the ignition die on the Cobra and after wiggling fuses it started back up??!! IT ALMOST GOT ME RUN OVER!!! " ?
It sounds like the car was in gear when it started?
Sounds like considering an entire new harness asembly may well be in your future. Installing a CR's at this point would not be impossible, but it would be a little difficult. Maybe an aftermarket harness such as Painless might be in order. Just a thought.
DV..we gotta be safe out there!
