November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-04-2005, 04:36 PM
Cobra Make, Engine: Classic Roadster with 427 center oiler
Default Don, a question about wheels and back spacing, Again!!
Hi Don
I just received an email form Vintage wheels that their 9.5 X 15 inch wheels are available in 4" back spacing. I was wondering if these would fit in the back of my '92 Classic Roadster with the '92 8.8 rear end.
I know, in the past, that you said 4" in front and 5" in rear. But I was wondering if the 4" would also work in the rear. Vintage Wheels does not make a wheel with 5" back spacing. And , if 4" back spacing will work, what is the largest tire that will fit ?
Paul
life is short: eat dessert first !
Old 06-04-2005, 07:52 PM
Paul, from first glance....the 4" backspace would work.....but....it's gonna make the tire/wheel stick out past the fender well.
What you also have to remember is that the Vintage wheels are knockoffs.....which requires a knockoff adapter...which will add another 3/8" to that....
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 06-04-2005, 10:10 PM
Blykins
I think the front wheels can be had in 3 1/2" back spacing. I am worried that the back wheels won't fit with a 4" back spacing. They may stick out past the wheel wells.
Paul
Old 06-05-2005, 05:28 AM
They definitely will stick out with the knock-off adapters......
My SV requires a 3.5 backspace on the front and a 4.5 on the rear....I've been through all of this backspace stuff....I've made AutoCAD drawings....I've bugged all the members....
There's no way I could fit a 3.5" or a 4" knock-off wheel on the rear without it sticking out....
I went with the PSE wheels....I think you've been in on that post too. I talked with great length to Richard Oben (he sells Team III and PSE's both) and he said that due to the way the PSE's are manufactured, I could get that deep Trigo look on the rears with a 4.5" backspace on a 9.5x15 PSE wheel. I think the Team III's are 3 piece wheels.....PSE's are 2 piece. The way Richard explained it to me, this makes a big difference in appearance.
Old 06-06-2005, 10:57 AM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
You guys are right, the 4" will not fit properly. The 7.5" fronts need 3.5" backspace, the 9.5" rears need 4.5" backspace. PS 7.5" front wheels are available with a 4" backspace but they will work on the front. This backspace will set the wheels just right in the wheel openings. The 15" PS wheels are a one piece, the 17" are a 2 piece.
Don
