Drive Shaft Loop??
Hey Don,
I've read a few threads about broken DS yokes under power and got an ugly image of what might happen to me if that happened!!:eek: Do you have a loop for our cars and if so will you need the chassis number or have they remained the same through the years??:cool: Thanks in advance!! Coosawjack |
Bump??:confused:
coosawjack,
I just used a hoop from Summit Racing. Worked well. Pictures and info over at my web site: http://www.birch.net/~petek/cobra/007/jul1.htm |
jack, the way the rear tunnel for the emergency brake is setup it will act as a driveshaft loop towards the top of the car. If you want to you can add a strap between the frame rails under the driveshaft to keep it from dropping to the ground.
Don |
Thanks Don......I'll take a look at it!!
I was thinking that if the rear U-Joint broke the shaft would likely just fall out but if the front one broke it could flail around and possibly come through the tunnel??:CRY: Coosawjack:MECOOL: |
| All times are GMT -7. The time now is 10:09 PM. |
