Like Tree1Likes
  #461 (permalink)
Old 09-18-2008, 03:26 PM
Double Venom's Avatar
I was actually thinking of cutting a corresponding "U" at the mouth of the air cleaner, OR leave it like it is. It will stay centered when enlarged.
DV
  #462 (permalink)
Old 09-18-2008, 03:31 PM
capteddie's Avatar
Send a message via AIM to capteddie
Not following you.
You mean cutting a U on the deck of the hood to match the radius of the cleaner?
If you can. Mark out what your talking about on the hood and post a picture.
Sounds interesting, if its what I think it is.
"the other ed"
  #463 (permalink)
Old 09-19-2008, 03:37 AM
eddie,
Much neater than my scribbeling but it should get the poinit across-just an out line of the lower section of rthe cleaner- strictly an option on your part.
Good luck today!
DV
  #464 (permalink)
Old 09-19-2008, 04:03 AM
capteddie's Avatar
That's what I thought you were talking about sweet, lets do it!!!!
Off to the hospital, later....
"the other ed"
  #465 (permalink)
Old 09-21-2008, 10:09 AM
capteddie's Avatar
Me and my back are back!!!
Well I have 14 staples holding my lower back closed and it feels like I'm learning to walk again, but everything went OK. Pain level is through the roof right now, but I've been told every day will make a big difference.
OK DV. I'm off work for at least the next 4 weeks, so you better keep me entertained
Cheers!
"the other ed"
  #466 (permalink)
Old 09-21-2008, 11:23 AM
James Stern's Avatar
Cobra Make, Engine: Classic Roadster, 302, roller cam, Holley 650
Default Captain Eddies' Back
Glad to hear you made it through with flying colors. I'm still in England but the suspense was killing me so I borrowed a computer from one of my God Children. I hope that you are back on your feet as soon as possible. It looks like DV is taking care of his end.
The one line never heard in heaven; "Gee, I wish I had spent more time in the office."
  #467 (permalink)
Old 09-21-2008, 11:29 AM
capteddie's Avatar
Thanks a lot Jim!!!
I'm sure DV is. Just trying to coax some new pictures out of him
"the other ed"
  #468 (permalink)
Old 09-21-2008, 08:46 PM
Cpteddie,
Welcome back already even! Sounds like it went ok, I've got one piece of foreign steel in my back, does that count?
I Just back on the internet....damm dial up! However, your roll bar material came in yesterday!
Anything newsworthy, you know I will post it sooner or later! Glad to here your surgery went well!
DV
  #469 (permalink)
Old 09-21-2008, 09:09 PM
MaSnaka's Avatar
I have the air filter cut out on my hood. I can't say I love it because it looks like an afterthought to make something fit. I had Curt Scott from cobra country comment..."wow I have never seen that before". If and when I get a chance I would rework my hood to eliminate that cut out where a small part of my oval air filter is exposed through the hood. My son says " Dad no one is gonna say your car is a pos because of that one detail" which I believe. But if you have other options I would consider them. Just my 2 cents. Glad to hear your surgery went well. I will post a pic asap.
  #470 (permalink)
Old 09-22-2008, 06:38 AM
My breather plate has the carb hole moved to position the breather back about 1-2". I used a threaded rod and spacer between the manifold and breather base to keep the breather from turning.
Terry
  #471 (permalink)
Old 09-22-2008, 07:24 AM
capteddie's Avatar
DV
Did the House of Kolor stuff show up yet?
"the other ed"
  #472 (permalink)
Old 09-22-2008, 07:43 AM
Guilty!
I'm forced to take a few days away from the cobra , I have purchased an out door wood stove to heat the house the shop, my neighbors house, both water heaters, both basements and his shop. (The trade off is he has to supply the wood and cut it for the stove ) . The problem is I have had to dig a trench 2' deep, 4"s wide, 250' long. insulate 500' of Kitex 1" tubing, then encapsulate the entire lenght of tubing in 4" solid drain tile, then fill the tile with insulating foam. Than bury it. 2/3's done on my side!
Tried it late last winter without insulation on the pipes. Had to turn the water heaters down- darn they got hot, the house got to 86 on my side my neighbor 100' closer to the stove than I am, house went to just under 90's, both unheated basements got to house temp and we hadn't even burned a half cord of wood yet! Man I love this thing.
We now have the heat situation under control,(getting the furnace to actually cool down between cycles) and my infloor heat in the shop is simply amazing!
I'm predicting a normal ussage of 3,000 gallons of propane a winter to less than 200 gallons a year. My neighbors propane should drop to way less than 100 gallons a year.
So, until I get my side done completely, (by tomorrow I hope) I have had to play hooky on the cars!
If you're in an area that allow these furnaces, do yourself a big favor and look into one. We finally went with a Hawkins Stove.
Back to my ditch then on with the car in a very warm shop!
DV
  #473 (permalink)
Old 09-22-2008, 08:52 AM
capteddie's Avatar
Please post a pic of your hood. I'd like to see how it looks. Maybe that would change my decision to have DV make the modification.
Thanks!
"the other ed"
  #474 (permalink)
Old 09-22-2008, 09:54 AM
capteddie,
Check out John's photo gallery, page 3.
Terry
  #475 (permalink)
Old 09-22-2008, 10:06 AM
capteddie's Avatar
I took a look Terry, but its hard to see the the modification. I was hoping he had a close up pic of the front of the scoop taken from the top.
Thanks again
"the other ed"
  #476 (permalink)
Old 09-22-2008, 12:09 PM
Cpteddie,
Your filter is not going to stick out as far.......... (As Johns)
DV
  #477 (permalink)
Old 09-22-2008, 12:13 PM
capteddie's Avatar
Ok... Go ahead and add the curve.
Are you done playing with your backhoe? Seeing that your online, your phone line survived this time
Did you get the stuff from House of Kolor?
"the other ed"
  #478 (permalink)
Old 09-22-2008, 12:51 PM
MaSnaka's Avatar
Boy you guys are moving fast. I posted some pics of the hood for you. Check them out in my gallery.
  #479 (permalink)
Old 09-22-2008, 01:09 PM
capteddie's Avatar
Thanks for the new pics John.
I actually like the look. As DV said, mine is not sticking out as far as yours. So I think the curve DV will put in will be less prominent than yours. But like I said, I like the look.
Thanks again John!!!!
"the other ed"
  #480 (permalink)
Old 09-22-2008, 04:12 PM
HOK, Nope not yet. No backhoe -all back! Just finished the insulation and pulling the last 50' of pipe covering it up! Piece of cake from here out! Probably start hacking the DOM material Weds?????????
DV
