1Likes
05-16-2010, 08:01 AM
IL
Hurricane HMS2002 build thread part II
High Maintenance Racing Team
Run & Gun 2003 - 2013
05-16-2010, 10:02 AM
MO
Cobra Make, Engine: FFR MKII - 460 Crate with Cobra Jet heads, 750 Quick Fuel Carb, and Edelbrock Torker II Intake port matched to heads
Engine bay looks awfully lonely
05-16-2010, 10:41 AM
Looks good Dean!
CAV GT40
05-16-2010, 01:44 PM
Nice Dean. I love that profile shot!
Alba gu brąth
05-17-2010, 09:52 PM
Go
very nice
SDR
________
Marijuana seeds
05-18-2010, 06:28 AM
IL
I've been working on the racing seat. It was a pretty straight forward install. The only problem I ran into was that I couldn't reach the pedals. I could reach them but I wasn't as close to them as I should be to operate the car safely so I put in a set of sliders.
I marked and drilled the holes in the vintage Kirkey seat.
I installed the sliders and bolted on the front riser. It didn't take long to fabricate the mounts.
All done!
05-18-2010, 07:44 AM
Cobra Make, Engine: Hurricane 427 Cobra #HM2008, Craft Performance 427w 600hp/600tq, TKO-600 close ratio, original Smiths gauges, lucas switches
Dean, just curious - how tall are you? I'm 5'7" and concerned about reaching the pedals. I sat in Jshel1's HM1038 and was quite comfy. John's about my same height.
Also, if the new cars use the lowered footboxes, are the brake and clutch arms shorter, so the foot pad is closer to the floor?
Bob Worley
Hurricane HM-2008 build is done!! (for now....)
Craft Perfomance 427W / 600hp / 600tq - TKO600
I love it and I need it I bleed it ~ Yeah it's a wild hurricane ~ Alright, hold tight, I'm a highway star!!
05-18-2010, 07:22 PM
IL
Well, I'm almost 6'3! The racing seat affords the driver much more room than the traditional seat. You should be fine with the regular seat and some pedal adjustment. It is rare that a car can accommodate such a wide range of driver.
Anyway back to the show!!
I added the heat shield for the brake master cylinders.
I am working on the secret compartment under the floor to store my whiskey and my pistol.  Or maybe my registration and my insurance card.
05-18-2010, 09:11 PM
Whiskey AND pistol... interesting!
Alba gu brąth
05-18-2010, 11:27 PM
Isn't that heat shield on the brakes a little thick? Seems like it will as much like a heat sink as a heat shield.
05-19-2010, 06:43 AM
IL
I don't think the master cylinders are in any danger from heat. I will have to wait and see exactly where the pipes go. There will be a lot of air flow and it could be directed under the shield. I never thought about the heat sink idea but it would certainly be easy to switch to a thinner material. Thanks for the input.
The floor on the Hurricane is an interesting piece. I didn't want the glove box and this answers the question about where to store stuff.
Here is the foot box. It looks normal enough. (I just noticed the sharp edge of the door hinge that I will need to trim.)
This is how it goes together.
Here is the finished compartment.
05-19-2010, 07:40 AM
Muy bueno!!
05-19-2010, 09:24 AM
Evryday is a roadstr day
Oh
Cobra Make, Engine: RHD Hurricane street roadster HM1081 aging nicely in the garage
If you have trouble with the edges coming up on you from moving your feet around, maybe a bit of velcro would be in order along the edges...
 aka Fuzzy ............... "It is not the return ON my investment that I am concerned about; it is the return OF my investment"....  ...from Will Rogers
05-19-2010, 12:11 PM
Looking good Dean. That will be another fine looking car.
05-20-2010, 02:43 AM
OR
Cobra Make, Engine: Factory Five, 302 powerdyne supercharged
So what is that compartment exactly for? Insurance info, etc? Looks like a smugglers dream compartment to me. Is it accessible while your in the drivers seat? Is that an option or is it standard equipment?
05-20-2010, 06:36 AM
IL
The compartment is intended to be used as a "glove box". I can be access from the driver seat and I'm not sure if it is standard but I know they will do it for you if you ask. It was an after thought. When I saw the available space, I asked them to create access to it for my stuff.
I painted the under side of the body black last night. No real good pictures but it had to be done. I should have done that before the body was put on! You can see some of it in the fender well and the engine compartment.
05-20-2010, 08:08 AM
Hi Dean,
Really great detail, love browsing through this build.
A couple questions:
Do you think the new placement of the master cylinders will be in harm's way?
Seems like they could catch a lot of road debris and stuff coming off the front tire.
I did not see the front sway bar in the engine compartment photos, is that still to come? You tease you!
Evan
HM1103 (First Gen, Aging gracefully in the garage)
05-20-2010, 09:41 AM
I think Dean will keep his Cobra stealing weapon in there...
CAV GT40
05-25-2010, 08:36 AM
IL
I am still on vacation with the family This week but it is hard to stay away from Club Cobra!  There is NO service near the Grand Canyon but I found a little in Utah.
To answer some questions, the sway bars are next on the list. It is a super easy install but I haven't done it yet. The brake masters have a steel lower guard. I can take some pictures when I get back.
Back to our regularly scheduled program......
I have been working on the brake ducting and the fresh air system. The first thing I did was install the brake duct fitting and screen in the front end. (this was before I painted the underneath black)
I used this 2 part adhesive from Eastwood. This stuff is really useful to have around. It isn't cheap but it really works well.
This is where I ran into problems. The Goodyear billboards are really big tires and as I was mocking up the brake ducts, I found that the tires hit the hose. I was going to have to run the hose up high then back down to the spindle and I really didn't like that idea so I had to step away and think about it.
I decided to work on the fresh air system instead. That should be an easy little project, right? Well I realized that I needed to finish the inner fender panels before I could do the fresh air system. That was a little bit bigger deal. But that is how it goes sometimes. The templates from the old Hurricane company didn't really fit so Hurricane created new templates and sent them down to me and you can see the difference. They fit great! These guys are so easy to work with.
That's it for now, headed to Bryce Canyon!
05-25-2010, 08:14 PM
IL
Here are some shots of the brake ducting at the rotor. They bolt right up to an existing hole on the spindle. I think they are going to work fine but a final test when the car is on the ground will tell for sure.
Some high heat black paint will finish them off!
