440Likes
08-05-2017, 07:07 PM
Cobra Make, Engine: Superformance, 427SO
Ya, they're all upside down for me. (no, I'm not standing on my head)
Ted
08-06-2017, 05:16 AM
NC
Upside down for me too.
John O
jjo42
08-06-2017, 06:42 AM
Weird, they are fine on mine.
08-06-2017, 06:51 AM
I'll just post narrative from now on.
08-06-2017, 07:32 AM
Keep posting the photos Bill. I can crank my head sideways to look at them if they're upside down  Just ribbing you a little. Been enjoying following your build.
Ted
08-06-2017, 08:00 AM
Darn it Ted, do you have your monitor upside down again.
08-06-2017, 07:11 PM
Oh, so that's the problem. I thought that big flat thing sticking out the top of the monitor was an antenna but I guess it's the stand ! Now that I've turned it over I don't have to lean it against the wall any more. Thanks for the tip Ron.
Ted
08-07-2017, 05:43 AM
Always glad to help Ted. Some of his pictures are upside down on the other site also and I have been trying to figure out why. I have set up a test account with the storage site he uses and so far all of my pictures that I load into it are right side up.
Ted
08-19-2017, 03:28 PM
08-19-2017, 07:46 PM
Bill,
Glad that you got the engine installed, sorry to hear that you will have to install the transmission from underneath. That is a lot of work. Do you have the tunnel installed at this point? If not, you might be able to have someone help from above you and assist with maneuvering and holding the transmission. On my build I was able to leave the transmission cross member in place and bring the transmission in form the passenger compartment with the tunnel removed. We were able to balance the transmission on the crossmember while I was underneath and then line the transmission up with the bell housing and get it in place.
Not sure if that will be possible with your situation. Those things are heavy and a pain to maneuver, even with a transmission jack. Good luck and be careful.
08-19-2017, 08:15 PM
I plan to raise the car high on jack stands, place the trans on a floor jack, and then maneuver the trans into place. Going to try it by myself first. If that fails, I have a friend who said he would help.
08-20-2017, 05:38 AM
Bill,
Good luck, be careful and let us know how it goes. Many a transmission has been installed in that manner. It is just a pain sometimes trying to maneuver it and keep it balanced given the tight constraints and weight.
08-27-2017, 05:52 PM
08-27-2017, 06:50 PM
SA
Well done Bill. So the gearbox install went OK? Was it a one man job as anticipated?
Glen
08-27-2017, 07:10 PM
Glen
Two man job. I got everything lined up and we just wiggled it in.
The body was more of a challenge
08-27-2017, 07:37 PM
NC
Oh that is sooo cool!  Way to go Bill.
John O
jjo42
08-27-2017, 08:05 PM
Congratulations Bill on a job well done. Looks great  You are eel on your way now. Have a cool one and relax.
08-31-2017, 12:21 PM
Installed a remote oil filter system and assembled -10 AQP braided lines and swivel fittings. Man, that stuff is a ***** to work with in such short lengths. A real PITA to route and tighten with AN wrenches.
But another task completed
Whew
08-31-2017, 01:32 PM
Whew
Yes Bill, that stuff is a pain  I hate working with it and my fingers still hurt from getting poked with stainless steel wire. Nice looking job.
08-31-2017, 02:13 PM
Hi Bill,
Can you tell me what make that battery cutoff switch is?
Thank you
