UK Based BackDraft 153 Revival.
Hello Everyone!
(Sorry this post is made up of a series of other posts on a different forum) I was looking at all sorts, Caterham's, Atoms, Cayman GT4's, GT3's and even a Macca 570s in one of my weaker moments. None of them though really got me going. The Caterhams were too samey when compared to what I had before and the Porkers were too much like 'normal' cars. Then the Mrs chimed in with why don't you get something you've always though was cool, and literally the first thing that came to mind was a Cobra. I've always loved them since been little. I've been around kit cars since I was 16 so know them inside out, whats good, what isn't, whats correct etc. So I set about looking, with my criteria list: As close to period correct visibly as possible Flat dash Offset shifter Open inner doors 15's with bubble tyres Correct riveted bonnet and hood scoop Correct body shape at the rear and front Side pipes And most importantly a Ford derived 400ci + motor Annoyingly wanting all of the above basically throws out all the UK made reps, bar the £125k ali bodied ones. Even AC's own repos all use LS motors now. The likes of Dax, AK and Pilgrim all have a design at the rear where it falls away too quickly compared to the real car, and the Pilgrim especially has an difficult front end. The UK ones also have really odd interiors with the dash and trans tunnel merging. They also generally have chevy 305ci's in them, as they are cheap and plentiful. As well as hateful 17" wheels! (Sorry owners with these!) So I was only really left with the American made reps (well the shells are done in South Africa). The two companies making the majority of these been Superformance and Backdraft. Now the search was a tough one, very few of these cars are in the UK, and when they get offered through a dealer, they end up being a huge price. Then you can add in the fact its impossible to see one atm and it made it stressful. Then I randomly found on on car and classic, which was local but had no price. Spoke to the owner, he said all the right things (sadly he got clobbered by Covid), so I've bought it unseen. Hopefully collect it this week! Short spec: Backdraft Cobra 427 SC Imported 2017 5000 miles since it was built Period correct bright work Extra passenger roll hoop Painted stripes Stainless side pipers 15" wheels Smeding Performance 418 V8. 500bhp/500lbft Built T500 gearbox LSD Collected it,...... 8 Weeks Ago..... https://cliosport.net/attachments/ff...-jpeg.1531685/ The paperwork is mental. Even have the copies of the payments cheques for the body ex engine from the USA. https://cliosport.net/attachments/5f...-jpeg.1531686/ First job was getting all those stickers off: https://cliosport.net/attachments/2e...-jpeg.1532259/ https://cliosport.net/attachments/b7...-jpeg.1532260/ CO2 aware in this household.... https://cliosport.net/attachments/3c...-jpeg.1532025/ Well... I’ve still not driven it and I’ve broken it... Was going through all the boring check stuff to make sure it wouldn’t fall apart when I first take it out. When checking the clutch range of movement the slave cylinder s**t it’s self. Only a £30 part though so no biggie. Better then it happening when I’m out and about! Also look at the harness’s, they are from a 1971 aircraft. I'm not using those!! https://cliosport.net/attachments/ad...-jpeg.1531951/ Week 2............. TRS harnesses ordered. As well as what I assume to be the correct slave cylinder too. The broken one is still on the car and I can’t be bothered to take it off atm. Hopefully have the first drive next weekend, weather dependant. Engine shots.... its a bit bling for me. Wi'll be making it look more original in the future. https://cliosport.net/attachments/a8...-jpeg.1532328/ https://cliosport.net/attachments/4d...-jpeg.1532330/ Photo of the car from when it lived in California! https://cliosport.net/attachments/ad...-jpeg.1532383/ Some parts have come! New clutch slave cylinder Bonnet gas strut Steering wheel frameless button holder Brass adapter for the vac gauge Still awaiting: High temp clutch fluid Funk motorsport clutch and brake line heat protection TRS Harness' Also ordered: Classic switch label set 1960 Lucas single push switches Clutch slave cylinder done! https://cliosport.net/attachments/62...-jpeg.1533179/ As you can see it was a right t**t to bleed. I’m glad my guess at a 1991 Landrover Defender slave cylinder was right though! Clutch all re set and it nice to use! Rolled out of the garage for its maiden drive. https://cliosport.net/attachments/5d...-jpeg.1533177/ https://cliosport.net/attachments/02...-jpeg.1533176/ Well..... Bad points: It runs lean on acceleration The near side front break squeals all the time The tyres had 16 psi in them It’s too low on the front and the tyres rub Steering is a proper effort at low speed Good points: LHD is fun! It’s sounds biblical It’s actually nice to drive The Mrs loves it It’s a f**king Cobra It shakes like a badass at idle All the little fixes I’ve done have make it better All in all I’m calling it a great success!! Neighbour update: 3rd noise complaint today... So after much reading I set about re setting the carb.... Carb update: Took the jets, metering rods and springs out. Found it was set to: 12% Lean cruise 15%!!!!!! Lean throttle No wonder I had issues. Now set to: 4% Lean cruise 6% Rich throttle So hopefully that helps. If not, I can go to: 0% Cruise 15% Rich throttle The current 21% swing in rich fuelling should sort me. Some photo's of how it stands now. https://cliosport.net/attachments/bb...-jpeg.1533336/ https://cliosport.net/attachments/67...-jpeg.1533339/ https://cliosport.net/attachments/29...-jpeg.1533340/ https://cliosport.net/attachments/33...-jpeg.1533338/ Oh yeah, also fitted all the funk motorsport heat proofing to my clutch and brake lines that pass the manifold. The lean saga continues. Carb all set up, idles fine, drives on light throttle fine. Lean as hell with any proper throttle. So popped round the parents in it, Dad wanted to see it running. Had the bonnet open, started it, running happily but.... Fuel pressure was through the floor, knocked the engine off and its back up to where it should be. The bloody fuel pump is on its way out! So to distract me from making this thing fuel injected.... I finished the interior. When I got it, I didn’t really show the interior. It had a Nismo wheel FFS.... So here are some before: https://cliosport.net/attachments/2e...-jpeg.1533711/ https://cliosport.net/attachments/49...-jpeg.1533709/ https://cliosport.net/attachments/4a...-jpeg.1533708/ And now, with new wheel, switch gear, labels and the daft carbon fibre panel painted black: https://cliosport.net/attachments/28...-jpeg.1533706/ https://cliosport.net/attachments/6c...-jpeg.1533707/ https://cliosport.net/attachments/98...-jpeg.1533705/ Week 3............ I caved..... Holley Sniper EFI unit https://cliosport.net/attachments/s-l640-jpg.1533915/ Just ordered an 044 pump which will 'just' about keep up with the fuel needs of 7000cc at full chat. Sniper on and half the wiring done. https://cliosport.net/attachments/21...-jpeg.1534277/ This is going to be an adventure.... This weekend So today was eventful. First off my new pump and filter sit very low! Low enough that I think they need a shield making. Other than that, got it all plumbed up. Ran the pump and fuel every where. The one bit of hose I hadn’t changed was leaking. Typical. Sorted that. Finished the wiring off for the sniper. Do all the settings, set the wizard off to make a map and..... all it’ll do is crank, no rpm signal. Test everything no issues, odd. Have a route for a better tach signal under the dash and what’s that? A bloody MSD programmable ignition unit. Who knew. Took the tach signal off that. Boom she starts, straight into a happy idle. Within 2 mins the guy from 6 doors down was on the drive, I told him to sod off and checked for any more leaks. All been well, time for a test drive. Within a mile I nearly lost a wheel. The cap nuts had bottomed out on the studs, so they could wind them selves out. Mrs came to my aid and I swapped the cap nuts for some open ones, sorted. By now the car was in warm and was idling at 2000 with the idle valve closed, checked for air leaks, none. Weird. Quick google and I hadn’t adjusted the hot idle screw. Idiot. Quickly sorted that and off I went for it to self tune. After 20 mins or random driving, for the first time ever I gave it all it had... HOLY f**king s**t This thing is fast. Did a bit more driving, got cold, went home. LOVE IT. |
Whoa looks like there's no auto resize going on here!
New surge tank mocked up. Hopefully fit it at the weekend and run new fuel lines through the car.
https://cliosport.net/attachments/b3...-jpeg.1535369/ So on to mocking up where the pumps and filters can live. For the test run, they were all just on where ever they'd fit, which isn't ideal for flow, seeing leaks or servicing. So I'm looking at moving them all to be in one place, underslung off the diff mount. I did a quick mock up with some ali hole board, hose in place of AN fittings and lots of cable ties. https://cliosport.net/attachments/17...n-jpg.1534942/ Its hard to photo, but they look a lot lower than they are, in reality they are higher than both the sump and the gearbox bell housing. They are around 20cm from the ground. I think though, I'll get them mounted to some ali plate then build in a stand off with a skid plate below them. The other option is to go up into the boot with them, but then you are asking the pump to draw upwards all the time and I think I'd see starvation issues. I could run a 1.5l swirl in the right hand side of the boot. Run the 044 straight off it. Use my weakened Gates pump as a lift pump under no pressure. The return line already goes near that side of the boot. Hmmmmmm MaxpeedingRods surge tank is here. How they make them for £25 is beyond me. Its REALLY good quality. Fuel system re done and I have 3 leaks. Two of the outlets on the top of the tank. The underside of the fuel filter. Been at it 7 hours today. Trying to be tidy. So those leaks can wait till tomorrow. Finished. Used copper hardline where I could up to the boot. https://cliosport.net/attachments/90...-jpeg.1536114/ Took the leaking joints apart. On the fuel filter the copper ring had a nick in it. The ones on the tank that leaked just needed the mating faces cleaning up. https://cliosport.net/attachments/34...-jpeg.1536113/ https://cliosport.net/attachments/26...-jpeg.1536112/ On the lift pump the electric fittings were push on, not really liking those I tapped them to M5 thread and put a lock nut on. Tidied all that up and sorted the wiring and it fired first time. Also junked the stupid oil breather lines and fitting some Moroso oil recirc caps. https://cliosport.net/attachments/84...-jpeg.1536115/ Happy days. Just need some sun now. https://cliosport.net/attachments/07...-jpeg.1536116/ |
I think I’ve found the cause of my squeal.
Ordered some top mounts, started with the one from the noisy side. Well..... There’s no grease in the baring, only sand.... that California life! The baring doesn’t even spin!! New one on, will do the other side tomorrow too. New above, old one below. https://cliosport.net/attachments/a1...-jpeg.1538346/ |
Go out for a little blast while the Mrs is on call annnnnnnd
Ping noise and now I have no speedo... Cable is still fitted on both ends so it looks like I’ve snapped it. Check the big book of cobra bits to find out what cable I need and I find out that in 5800 miles it’s had 6 cables.. So, the issue is the routing at the gearbox end, which I can’t change, so I have a few options: 1) Import a $100 custom cable for it to break in 1000 miles ish. 2) Take the feed from a VSS sensor on the diff, like a E36 would, run it through a $300 converter and potentially still have an issue with the 90 degree gearbox behind the gauge 3) Buy a $360 GPS to mechanical converter (not strictly legal in the uk) and potentially still have an issue with the 90 degree gearbox behind the gauge 4) Spend £300 on a new electronic gauge and a gps feed unit Leaning to option 4 atm. Ordered a Smiths 100mm electronic Cobra style gauge today along with a Veethree gps sender. New (to me) Smiths reverse sweep Cobra speedo is here. I’ve rigged it up to work from a 12v plug supply as I have a little project I want to try with it. https://cliosport.net/attachments/77...-jpeg.1539639/ As you can see it’s on 1547 miles. My Cobra is on 5900ish. I want the mileage on the new speedo to match. Smiths in all sensibleness make them neigh on impossible to manipulate the mileage (for good reason). So I need to think laterally. Each mile requires 16000 pulses to the speedo. If I set it to a feed at 761hz using an Adrino I’ve programmed it should set/run the speedo to 170mph... the stepper motor will have a fit if I set it to over 180mph, so 170 has a bit of safety built in. I need to add 4350ish miles to it, so it’ll have to run for 25 and a bit hours. In that time it’ll deliver 69,600,000 pulses and bobs your uncle the mileage will be correct on the new gauge. Should be fun. Its only bloody working! https://cliosport.net/attachments/4b...-jpeg.1539673/ Speedo also overreads by 1mph at 170! Great success. https://cliosport.net/attachments/0f...-jpeg.1539843/ https://cliosport.net/attachments/1b...-jpeg.1539844/ |
Shopping car!
https://cliosport.net/attachments/54...-jpeg.1541926/ New wheel bearing too. https://cliosport.net/attachments/24...-jpeg.1541928/ In other news… turns out I had a squeak and a chirp. Top mounts fixed the squeak. The chirp is still there… new wheel bearing ordered. https://cliosport.net/attachments/0b...-jpeg.1542031/ Bearing seemed to pull off nicely, till I saw the inner race was still on the stub. Had to take the grinder to my small pulley puller, to make it pointy-er. Then with some cable ties and mole grips the inner race came off. New bearing on, went on lovely. Brakes all back together. Took the studs out of the old hub and they were copper greased in! Cleaned all that s**t off and re fitted them in the new hub with some loctite. Hopefully give it a drive this week to see if it’s all fixed. |
Finally it’s something like finished.
It doesn’t even squeal when you are driving along anymore. Went to get some milk in it. Good car. https://cliosport.net/attachments/17...-jpeg.1543003/ |
After doing 200 miles in it over the weekend, I've decided it could be even better.
The steering is very direct but the column at the steering wheel moves about 1mm in all directions, which gives a horrible disconnected feeling. Most classics have this kind of float, due to rubber/plastic bushes and not overly tight tolerances. So I've stripped the upper column out of the car. on measuring, I think I can get some proper needle bearings in there. I've ordered some press on inner races and correctly sized needle bearings to try. Sadly I've not got enough room to get some conical bearings in there, so I will have to just use tension to stop thrust movement in the shaft, but that shouldn't add any more weight to the unassisted steering. Its also time for me to accept my temporary placement of the wideband 02 sensor in the cylinder 1 manifold branch, is no longer good enough for fine engine tuning. So I'll be adding a boss onto my 4-1 collector to hopefully give me that extra level of accuracy for part throttle tuning. I've also noticed my belt run is being dragged off line by the alternator pulley, so I'll be shimming the alternator to get that perfect too. Good job its raining this weekend! |
Good work. Beautiful car. BIG photos. Have fun.
| All times are GMT -7. The time now is 05:05 AM. |
