Old 06-02-2008, 04:11 PM
jeff.nel's Avatar
Cobra Make, Engine: Contemporary, FE 427
Default Turn signals
I was wondering if anyone had any ideas for me. All four turn signals work normally. When I turn on the headlights, None of the turn signals flash except the right rear. Any Ideas?
Jeff Nelson
427 C' Ya
CCX #3117
Contemporary Classic Cobra Owners Group Member
Windy City Cobra Club Member
Old 06-02-2008, 06:27 PM
48 IDA's Avatar
Cobra Make, Engine: 1965 Contemporary 427 SC. built in 1982 before CCX serial #. has body #106. engine 351-C with 48 IDA'S 500 hp, T-56 6 speed, Halibrands k/os. Featured in KIT CAR, MOTOR SPORTS MONTHLY, AUTO X, AND SPORTS CAR. Original owner/builder
Default turn signals
Jeff, The first thing to do is check all your grounds for the lights.
There is a black box, (at least on mine) mounted under the dash that
controls the current to the turn signals lights. It is designed to work
the turn signal, and brake light on a single circuit. If all the lights
come on and only one flashes, I would suspect this signal flasher box.
Check for power going into the box, and if you only have one circuit
working coming out of the box. I would replace it. I believe that you
are able to pick one up from a towing supply outlet. U Haul. It will
be a flasher control for a single circuit brake and turn signal bulb system.
This unit allows the bulb to flash while your foot is on the brake pedal
indicating the way you wish to turn.
There are two flasher control units. One works with a single bulb brake
light and turn singal. The other with seperate brake light bulb, and turn
signal bulbs. Just wire in the box per directions, and you will be ready
to go.
Good luck
Don
Old 06-02-2008, 07:26 PM
1985 CCX's Avatar
Jeff
I second that! Great explanation Don.
Jeff
Old 06-03-2008, 03:06 PM
jeff.nel's Avatar
Thanks Don...I'll give it a shot.
Jeff Nelson
427 C' Ya
CCX #3117
Old 06-04-2008, 11:43 PM
Cobra Make, Engine: Early Contemporary 427SC w/ '66 427s.o. (car built in '79) by Snow White Rods (Fresno, CA); XKE Series II front/rear suspension (AMP lower A-arms/half shafts), CWI rebuilt IRS, 4-spd Toploader, PS Engineering knock-off rims.
Send a message via AIM to gjcomb Send a message via Skype™ to gjcomb
Don;
Good information that I am going to try. On my setup, everything electrical works, EXCEPT my turn signals and its been driving me nuts...I have an older Contemporary car - what does a diverter box do? This sucker is sealed...
I'm going back to hand signals...George
Old 06-05-2008, 10:06 AM
Cobra Make, Engine: Contemporary CCX33344 with original bore 427 SO.
Default Flashers
George,
My CCX turn signals drove me crazy (intermittent) until I isolated it to the trailer converter box. I ended up opening the box and replaced one of the relays inside. They are standard relays and are available at Radio shack for little $$$. I chose to replace the relay rather than the entire box in order to maintain the proper wiring and color coding for any subsequent owners who might need to trouble shoot.
Ray
Old 06-05-2008, 10:35 AM
Default Flashers
Another thing....the turn signals are sensitive to the type of flasher used. The CCX instructions recommend an Ideal #550 flasher. Since your turn signals work until the headlights are on, I would suspect the flasher. I vaguely remember a thread about this in Clubcobra in the past. you might want to search.
Old 06-05-2008, 02:37 PM
Ray - thanks for the information on the trailer box - I haven't opened it, but I will check it out.
I take it that you have the original written/typed wiring info and color coding that Contemporary provided in their manuals, correct?
Although my headlights are on with no problem, I will follow up on the flasher to make sure I have the right flasher.
George
Old 06-05-2008, 07:54 PM
Cobra Make, Engine: Contemporary Classic CCX 3970: 1965 427 Cobra S/C, Shelby aluminum 427 CSX 290 (468 cu in) engine
Have you been praying regularly to Lucas, Prince of Darkness?
Old 06-08-2008, 10:50 AM
jeff.nel's Avatar
Problem solved. Previous owner jambed the wrong bulbs in the front turn signals. It was shorting out. Replaced the sockets and put in a new brake witch and seems to be good to go. Thanks for the advise guys.
Jeff Nelson
427 C' Ya
CCX #3117
