-   Contemporary Classic Forums (http://www.clubcobra.com/forums/contemporary-classic-forums/)
-   -   Front End (http://www.clubcobra.com/forums/contemporary-classic-forums/96066-front-end.html)
Danr55 04-06-2009 06:52 AM
Front End
When setting up the front end, how much camber angle do you use? I've got a shake in the front end that starts at 75 MPH and doesn't go away. Tires are balanced, wheels are round, front end is aligned. I've run out of ideas.
patrickt 04-06-2009 07:17 AM
The ERA 427 cars are set for 0 degrees of camber, +/- 1/4.
Bob Perry 04-06-2009 07:56 AM
Dan , As per the contemporary assembly manual . TOE IN 1/8 .-CASTER 3-5 degees. -CAMBER 0 degrees (can be slightly negativeto suit drivers preference) hope this helps also you may want to find a good jag mech. who knows the front end and has the shims for it. Bob
Danr55 04-06-2009 10:04 AM
Thanks Bob. That will work.
