NASCAR vs. Std Toploader
http://www.clubcobra.com/forums/david-kee-toploader-transmissions-inc-speak-david/43985-nascar-vs-std-toploader.html)
| Marko |
08-02-2003 10:53 PM |
Is it necessary to go with a NASCAR unit in a CSX 4000 Cobra with a 430HP 390/406 engine? I'm getting conflicting info. I want to go with wide ratio gears, so a 28 spline unit is a possibilty. What would you recommend? Thanks.
| David Kee |
08-03-2003 08:34 AM |
Marko,
With a 390 you can run the small shafts. With a 427 or 428 you should run the larger shafts.
| All times are GMT -7. The time now is 04:46 AM. |
