Got to drive my car
Finally got to dive the car - wow - an absolute blast. I cannot stop smiling. We've been at it for several weeks. I know you guy's have seen hundreds but none of those are mine :LOL:
Still much to do, but we are on our way. Checking for leaks - we pulled all of the ancillaries off the front of the engine and reworked a lot of the layout. http://imageshack.us/a/img195/4950/cliffu.jpg Squared the throttle linage and built steel fuel line and routed around back of block. http://imageshack.us/a/img594/166/throttlelinkage.jpg Re-routed oil lines, moved coil to front of block, swapped in aluminum water pump, swapped in new MSD distributor. Both the water pump and Distributor showed a lot of corrosion. A little oil weeping here. http://imageshack.us/a/img820/2279/remoteoil.jpg I just have to have the look and feel. http://imageshack.us/a/img809/2804/enginedb.jpg So my alternator hook up is kind of weird - we were able to find a suitable dip stick and move it to the head. :) http://imageshack.us/a/img543/1082/alternatorz.jpg The car is sitting high at the front (5.375) with the rear at 5.0. I assume this was done to get the front of the pipes out of the dirt. http://www.cobracountry.com/cobra4sa...8a-640x338.jpg Had the side pipes reworked and squared to the car. We will be painting these black and lowering the front to 4.75. http://imageshack.us/a/img831/2451/newpipes.jpg It drives really soft. At times it feels like it is porposing. We are going to mess with the front shocks some to see what we can do. I had to purchase a new wheel and Les Schwab filled them all to 35lb on remount. The car would hop under hard acceleration out of first. I lowered the tires to 24f 26r and it has not hopped since, so I am encouraged. We badged the car last night and are in the process of converting to bumpers. - I wish ERA had a suitable badge to go on the rear deck lid - it would be perfect. Have a new 650 Speed Demon to bolt on in the next few days. This is an outstanding forum - an unbelievable amount of knowledge shared here. If anyone could advise me on the proper spanners for the shocks it would be appreciated. x-cliff |
Those pipes did start out kind of funky but from the looks of the second picture it appears that you got them worked out. Nice looking car. Your in the fun stage now.
Dan |
Awesome car!
Congrats! |
Congrats on the drive, wishing many (s)miles in the future!
Thanks for the compliments -
I have been able to drive the car three more times. The first time we added 8 clicks of dampening into the shocks (they were set at zero) and it was a major improvement. We had a dry day and took it down Skyline drive to Cornelius Pass and then looped back to Portland using HW 30 along the Columbia river. It was a major improvement, but with a full fuel tank and 400 lbs of passengers it still proved a little soft at the rear. We put it back on the stands and and added 2 clicks to the front (10) and 4 clicks to the back (12) and started working on ride height. We dropped the front until the front lower control arms were parallel with the floor. I have been unable to find any info on E.R.A. design goals with respect to the suspension e.g. where are the optimal roll centers based on control arm inclination. Once we were parallel to the floor I stopped dropping the front. The stance just did not look right from old pictures (which is probably not right since we are not running leafs) so I decided to pick the rear up 1 turn. There was a window in the rain Wednesday night and we pulled it out and took it for a run through the Terwilliger turns on I5 headed north. This is down hill and we got to run it thru the corners at 70 with much,much,much improvement. It tracked the corners very well and for the first time I felt like I knew where it was and where it was going except the turn in was amazingly quick (perhaps needing more castor). We put it back on the stands and lifted the rear another full rotation. It rained Wednesday night which knocked a lot of leaves on the ground. With the new ride height we headed out to German town road around noon. It was not raining, but it was very wet with wet leaves on the road. German town rises from the river I would guess 1000 to 1500 feet in around a mile + with switchbacks in the 180+ deg range. I chose this route because it was uphill and I wanted to get an idea of the swing weight of the car. I never even got around the first corner. I cut the speed going in and threw the car just hard enough for centrifugal to have its way (25 mph ?) and I was immediately sideways and not able to recover. Got it all straightened out and was much more respectful with the rest of the climb - big; round, and smooth transitions. The slightest boost in throttle and I could feel it spin. We found a way back down to the river with a descent which included lots of switch backs. I still tried to drive it with some kind of rhythm, but was very much on edge. Still - I was still able to get it to transition, but not where centrifugal was going to stomp me. From there we ran it 50 miles on freeway around the city - 80mph - 2000 rpm - with the windows on we could easily converse and it was very smooth. I do not understand the roll center on the Jag suspension. I assume it is at ground level with the lower arms parallel. I think I have a couple of degrees of inclination (higher at inner pivot) in the rear lower control arms at the present ride height ( have not measured). It does handle much better with the rear chassis higher than the front. Do you guy's run the rear arms parallel? The way it sits looks great - feels stable - but needs an alignment around these settings. I don't want to waste my money if there is a more optimal starting setup. The build manual only relates to chassis height from the floor which negates control arm inclination. Maybe it is toleranced that well. I was able to weigh it - with a full fuel tank - 2580 => with me 2740 Distribution 51R 49L => with me 49L 51R Fore Aft 49F 51R Painted the pipes but bumping off the rev limiter cooked it. :) http://imageshack.us/a/img526/8161/standsl.jpg Upgraded Throttle Linkage http://imageshack.us/a/img607/2076/linkage.jpg Swapped the Edelbrock 750 for 650 Speed Demon - http://imageshack.us/a/img826/81/demonj.jpg http://imageshack.us/a/img94/1171/buttuu.jpg |
| All times are GMT -7. The time now is 10:46 AM. |
