Front Pivot Points
I purchased poly for the pivots on the front of my car. When we started to take it apart, I was a little surprised to find the front suspension would not freely articulate with the shocks removed. The spindle and rotor weigh 35lb and I had to force it into the bump limit. Released, it would not drop further than half way and this was after letting it sit all night. I assumed it was because of the use of rubber in the joints.
We installed the poly bushings in the lower arms only, torqued the bolts to spec, and the arms were bound such that they would not drop with a 16 lb weight on the arm. After just a few cycles one the the bushing flanges was severely deformed and had been cut thru - hmm. I ordered a new set of bushings and we went to work on what was causing the binding. The first thing we did was to pull the bushings and cut the flanges off of them. We reinstalled them into the the control arm tubes and reinstalled the arms. http://imageshack.us/a/img195/5340/img0196jc.jpg By cutting the flanges we could measure the gaps between the bushing tubes and the pivot mounts. With the flanges removed I rotated the lower arms and noticed the tube ends were not vertically parallel to the pivot mounts. I had the faces squared on a mill and we reinstalled. Things rotated squarely and freely until we torqued them - still way too tight. I found specs from the bushing manufacturer that stated the control arm bushing tubes need to be 1.480 long. The tubes on the arms measured 1.520. I had the tubes milled down to 1.490 and we reinstalled. Still the arms would not allow 13lb to drop. We ordered a piece of 5/8 drill rod and slid it thru the pivot mounts and neither side would accept the rod. http://imageshack.us/a/img22/7750/img0161m.jpg http://imageshack.us/a/img547/4394/img0155rf.jpg http://imageshack.us/a/img708/1310/img0160ul.jpg http://imageshack.us/a/img824/9153/img0143vh.jpg I was a little startled by this at first because I was not sure where datum was. The good thing is the rod contacted at different points on the back pivot mounts. We grabbed a tape and the rods were both parallel to each other and parallel to the ground so we went with the front cross member being datum. We used a die grinder and opened the holes in the rear pivot points to allow the rod to slide thru. We welded in new locating washers on the rear pivot mounts. The rod now cleanly slid thru the pivot mounts. We ordered another rod and checked the alignment of the control arm tubes and it became apparent why the ends were not parallel to the pivot mounts. The rod would not pass thru the arm tubes - hmm. We cut three sides of the weld that attaches the tube to the arm, heated the remaining weld with a torch, and rotated the tubes parallel to the welding table until the rod would pass thru the tubes, then welded it all back together. We put the arms back on the mill and took the tube lengths down to 1.480 assuring the ends were parallel and vertical. I have always liked Prothane bushings because they mold grease grooves in to the I.D. of the bushing. Prothane does not publish any dimensional data on their bushings so I went with Energy Suspension. To achieve the same thing, we milled 6 shallow longitudinal grooves into the bushing sleeves. We installed zircs in the top of the tubes. Side note - the bushing sleeves supplied with the bushings fit the pockets nearly perfect - no more than .020 clearance. We put it all back together and it will barely hold a 6lb weight. Once it begins to drop, it is straight thru. There is an ever slight amount of static friction I believe between the bushing flanges and the pivot mounts, but it is nothing in the big picture and most likely will wear in. We are replacing the top arms with some adjustables from Specialty Products http://www.jegs.com/images/photos/800/827/827-92556.jpg They come with hard bushings, zircs, and swing very freely. We reassembled with just spindle and the assembly lifts very easily and falls very quickly. :) |
Nice work!
Thanks - anxious to try it, but that is months away :(
Interested in seeing what camber/caster numbers you settle on with the adjustable UCA's. Can you give us a p/n and source for these? I know I've seen them in the Speedway Motors catalogue, but where did you get yours?
Thanks, Allen. |
Do they sell a ball joint with a taper that matches the Camaro upper that we use? Is there enough angular freedom so that there's no bind in jounce or rebound?
http://www.spcperformance.com/images...C-Race-Arm.jpg |
The image I originally posted is incorrect - please forgive me - I re-posted the image above and a link below to the product. I purchased the arms from Jegs. There are two sizes. I tried the smaller - no good. They are not to be run with more than one inch of exposed thread beyond the jam nuts. We could not achieve this with the shorter arms.
Specialty Products 92556 SPC Race Style Adjustable Upper Control Arms We have it all bolted together just to align to the spindle and get the thing back on its wheels. On the rack everything cycles very smoothly, with no binding, from full bump to full droop and we have not had to modify the aluminum panels. That said none of it is set to spec, everything is prototype, but it all looks very promising. We had to move our machine shop so we had to pull off, but hope to be going again next week. We want to try to run the cross shaft directly against the upright - we have not studied that geometry yet with respect to maintaining the original timing. Bob, if you can give me any insight here it will be appreciated. Specifically - if we pull the alignment shims and mount straight to the upright, will we affect the timing such that it could not be adjusted in the arms provided the arms have enough adjustment? It is the location of the upper pivot with respect to the lower I am concerned about. The SPC cross shafts are not offset so we will have moved the pivot point inboard by the amount of the original cross shaft offset + the thickness of the alignment shims. I just don't quite have my mind around this yet. If the proper timing cannot be achieved, we will either run nominal block spacers behind the cross shaft or use the original Moog cross shafts or a combination of both and then fine tune with the arms. I purchased Howe low friction ball joints (upper and lower) and some Energy Suspension dust caps. I supplied Howe with the the part numbers specified in the build manual and they sent me the joints. Howe Racing Enterprises I have a caster camber gage that threads onto the spindle so that is how we will set it up. Ordered the Penske's yesterday. Is it all going to work? - I have no idea, but we are entertained and I am very excited to try it out - it operates very, very, smoothly? :) Bob - you guy's built the coolest thing ever - it is a joy to work on - thank you. chr |
| All times are GMT -7. The time now is 02:53 PM. |
