| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
1Likes
Post By Pete Munroe
11-05-2014, 09:22 PM
CA
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Fuses...older vs newer? type
All,
Blew the parking light fuse (#6) while messing with the front turn signals. Replaced with a spare AGC 15amp fuse.
Went to buy more. All I saw were "FAST BLOW" (obvious with the thin element) and "SLO-BLOW" (a heavier but TWISTED element).
OK what ever happened to just a "STANDARD" all purpose fuse? Is the older "STANDARD" style...lead strip with a notch in the middle...now replaced by the SLO-BLOW with the twisted element...?
Have used a magnifying glass looking at the old fuse that blew but can not find any part number/description beyond, at one end, "32V" a "logo" of some sort, and "SA" in a circle)...the other end has brand, style and amp rating "BUSS AGC 15A".
So what I call the OLD type "standard" heat range fuse (with the lead strip) now the equivalent of the currently marketed "SLO-BLO" with the twisted element...?
Think the NAPA store still has what I call the "older type" but the other chains very few if any. On line you can't really tell what you are looking at as the photo could be of anything.
Thanks, Pete
ERA 289 #2027
11-06-2014, 06:09 AM
CT
The slow-blow type gives you a little leeway, especially with motors that draw high starting current. I normally use slow-blow in all the firewall fuses. On the other hand, I use fast-blow for the two fuses (under the steering column) between the trailer relay and the rear tail lights. That's to avoid damaging the relay should you accidentally short out the wire.
11-06-2014, 12:29 PM
AR
I've had trouble sorting this out also. Finally ran into a lady at a NAPA who helped me finding something that qualified as a slow blow fuse - I think.
11-07-2014, 12:08 AM
CA
the new SLO-BLO...is it LEAD FREE??? and why add the label?
All,
Thanks, I do understand that the intended application of the FAST-BLOW ...ie: electronic circuits or relays...SLO-BLOW used for high surge circuits like lights and motors.
Mainly I was confused as to why the newer fuses had the label SLO-BLO added?...the old ones had no label, so why add one now? New type of fuse?
All I can think of is the older, unlabeled fuses use a flat LEAD strip as the element...and the lead is now banned from manufacture?
The new fuses now labeled SLO-BLOW use a "twisted wire" element (which, I am guessing is lead free).
I suppose the newer "twisted wire" element, at first glance, looks similar to a FAST-BLOW fuse's single thin wire element, so they added the SLO-BLOW label.
Still confused me...anyone know?
Pete
ERA 289 #2027
11-07-2014, 03:53 AM
SA
Cobra Make, Engine: CR Cobra 3169
The problem the old glass fuses had, that over time with heating and cooling, it would loose contact in the cap ends, so it looks fine but creating a resistance or no circuit. The spade fuses are better.
JD
11-07-2014, 01:43 PM
CA
Thanks for the response. Never knew why the old glass tube type were dropped about 1981 for new production automobiles...makes sense, and gosh the colors are so koool..........
OK, sticking to the glass tube type...LOOK at the ELEMENT in side the glass tube...
1. in a OLD TYPE "unlabeled glass fuse"...(which ACTS like a SLO-BLO but was NEVER LABELED SLO-BLO) the elements I see are usually ~1/8th inch wide lead strip notched in the middle.
2. in the NEW type SLO-BLO fuse...now PROMINENTLY LABELED "SLO-BLO"...the element is a twisted wire...I am guessing the wire is LEAD FREE.
The new type SLO-BLO at first glance looks VERY similar to a FAST BLO fuse...both use a wire element. But if you look close the new SLO BLO "lead free" element wire is TWISTED and a heavier gauge wire than a FAS-BLO.
To keep the newer wire style element SLO-BLO from being mistaken for a "FAST BLO" fuse they felt the SLO-BLO label was now necessary...just my guess.
Man this got too complicated...sorry about that.
ERA 289 #2027
11-07-2014, 02:11 PM
AR
So to get this all straight - visually:
Slo blow - flat, notched element or twisted wire element
Fast blow - single, thin wire element
Is this correct?
11-07-2014, 02:57 PM
CA
wish I had said that...
Dan,
Think you did a GREAT job making it simple...and correct as far as I know...hey, what HE said...!!!
A fuse with NO LABEL that has a flat, notched lead strip has "SLO BLOW" characteristics.
A fuse LABELED "SLO-BLOW" and with a wire element thick enough to be twisted is a SLO-BLO.
A fuse labeled FAST-BLOW label probably also uses a very thin wire element.
If you always double check ratings, and never assume you have the correct fuse you probably won't experience a automotive Chernobyl.
Pete
ERA 289 #2027
11-07-2014, 05:03 PM
AR
Great - I learned something to retain from this.
Thanks
11-08-2014, 09:17 AM
ct
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Good tread, thanks
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
| Thread Tools |
| Display Modes |
Hybrid Mode
