December 2025
Like Tree8Likes
  • 6 Post By Tommy
  • 1 Post By Tommy
  • 1 Post By twobjshelbys
Old 11-28-2021, 12:45 PM
Cobra Make, Engine: ERA 744/428/TKO 600
Default Stainless steel side pipes
I’m looking for a set of side pipes for a 428 powered ERA. I would like SS, but if that’s not an option, I could do regular steel. I tried GasNPipes but they can’t get the SS tubing for the primaries. I’ve been waiting over a year. Thanks…
Old 11-28-2021, 02:50 PM
Tommy's Avatar
GP Headers fabricated headers for my Cheetah. I fabricated the side pipe portion, but I suspect they can do whatever you need.
This shows the mock up I sent them and their finished work.
Dwight, rads42, 1985 CCX and 3 others like this.
Tommy
Previously owned EM Cobra
Old 11-30-2021, 05:01 AM
Very cool mockup jig for the headers Tom. What did you use for the moveable joints?
Jason
Old 11-30-2021, 05:26 AM
Tommy's Avatar
Jason
GP Headers sent all the metal parts of the mock up. All I had to do was add common PVC pipe cut to length, set the elbow angles and lock everything in place. Header clearances on my car were very tight and the finished headers fit like a glove.
sea2jet likes this.
Tommy
Old 11-30-2021, 09:49 AM
twobjshelbys's Avatar
Simply ingenious way to measure!!!
rads42 likes this.
Tony
CSX4005LA
Old 11-30-2021, 10:27 AM
Cobra Make, Engine: Kirkham #259
Is #8 tube longer for a reason......
Morris
Old 11-30-2021, 05:15 PM
Tommy's Avatar
Yes, to clear the steering column. .. This is a hot rod rather than a track car, so optimizing the exhaust length was not a priority.
Tommy
Old 12-01-2021, 07:07 AM
1985 CCX's Avatar
Looks like the company sends you the moc parts. Then they MFG the units?
Very cool....
Old 12-01-2021, 07:51 AM
If you can get Georgie @ Gas-N to tell you the center-line radii he needs for the inboard and outboard tubing to correctly nest them, these folks can make the tubing bends he needs.https://russellstubeforming.com/rota...ding-services/
IF he doesn't know the radii used (hard to believe)then he can at least tell you the gap between the pipes needed for the merge collector then the radius of each pipe can be calculated.
Old 12-02-2021, 07:33 AM
G_Edmonds's Avatar
Cobra Make, Engine: Classic Roadster, 408 LSX
I had a race car builder make mine locally, Got him the Classic Chambered mufflers I wanted and he built the rest from stainless. Obviously you can’t get to him but there’s probably someone in your area.
I've spent most of my money on cars and women. The rest I wasted.
Old 12-06-2021, 08:11 AM
Georgie frequents this board so hopefully he will reply. I’ll bring it to his attention as well.
He used my ERA pipes to create a fixture, just can’t get the tubing to create them.
Old 12-06-2021, 10:04 AM
Senile Club Cobra Member
Georgie and his crew were in our shop over the weekend prototyping more Superformance parts (we will have both MK II [289] and MK III [427 chassis]) headers, side pipes and UNDERCAR exhausts! Multiple header flange types to properly fit the common exhaust port sizes and styles will be available. The flanges they use are thick and allow proper torque on the header bolts.
Georgie related the issues with supply chain currently, everyone seems to be affected and not in a good way.
Gas-N is a quality supplier that goes out of the way to produce a top shelf product.
rick@autoventureusa.net
Old 12-12-2021, 05:53 AM
On another note, when GasNPipes used my Stainless Specialties pipes to create a fixture for creating new ERA side pipes, they installed new mufflers. When I received them back freshly polished, there is welding splatter on them. Can anyone suggest the best way to remove it? Georgie is willing to address the issue but it involves me removing the pipes and shipping them back. I would rather try and do it myself and on the car. Thanks.
Old 12-12-2021, 06:50 AM
DanEC's Avatar
I would try a small chisel first to see if it will pop them off. If they are too “welded” on for that the you may need to take a small, fine file and file each one down flat. You could also try some fine Emory paper wrapped around something flat like a pop cycle stick but a small, fine file would probably do best. Then you have to start sending the area with whatever grit will remove the file marks - probably in the 180 to 320 range and progressively sand with finer grits down to about 2500. Then get a small buffer wheel and some compound for stainless and polish them out. It’s a lot of work. I’ve restored my share of stainless and aluminum trim but I use a buffer motor/big pads which speeds the polishing a lot.
ERA 782 Running
Old 12-12-2021, 03:33 PM
Thanks DanEC, very much appreciated….
Old 12-14-2021, 12:15 PM
Cobra Make, Engine: ERA #720
Shell Valley sells headers and side-pipes for 90" wheelbase cars with both big and small block choices. Unfortunately it doesn't look like they're offered in S.S. so you're out of luck there Sea2jet but I wonder if anyone has ever tried them on an ERA? I'm not in the market yet, but when I am I won't be looking for S.S. and they're priced reasonably.
