-   -   Getting a more "correct" steering ratio (http://www.clubcobra.com/forums/era-speak-bob-putnam/147573-getting-more-correct-steering-ratio.html)
Grubby 01-26-2024 09:37 AM
Sometime back, Rick Mignone, showed how he modified a fast ratio Flaming River rack for his ERA. The goal was to get a steering ratio close to the originals.
Flaming River sells a fast ratio rack that is different from the ERA Flaming River rack in 2 areas.
1. Long pinion (input shaft) vs short for ERA
2. Mounting locations are rear of the ERA mounts by about 1"
I liked what Rick did, but went a slightly different way. First I took the fast ratio rack apart and had the pinion shortened and splined to match the ERA. Then I plan to take the fast ratio pinion and rack and install them into the ERA steering rack housing. It will then be visually identical to the current ERA setup and have a ratio closer to the originals. 15:1 vs 20:1.
ERA cars are currently about 3.3 turns lock to lock. Shelby Cobras were 2 turns lock to lock. The modified rack will be 2.4 turns lock to lock.
Some pictures are attached to give an idea of the process. My good friend took about a year to machine the pinion. He is slow but good. The big problem was finding a definition and dimensions for the splines. We ended up using an optical comparator at a large aerospace company to figure out the spline angles and dimensions. They are simple 90 degree splines and we got the ID at the bottom and top of the splines.
Flaming River says the racks can't be taken apart. I will show some photos of the assembly of the new unit. It may take me a few months to get to it.
http://www.clubcobra.com/forums/pict...=21174&thumb=1 http://www.clubcobra.com/forums/pict...=21175&thumb=1 http://www.clubcobra.com/forums/pict...=21176&thumb=1 http://www.clubcobra.com/forums/pict...=21177&thumb=1 http://www.clubcobra.com/forums/pict...=21178&thumb=1
DanEC 01-27-2024 05:23 AM
Interesting. I probably knew the ERA ratio at one time and forgot, but I would have suspected it was faster than 20:1. It seems faster than the 17:1 ratio in my 66 Corvette but the ERA effort is much lighter. Let us know how it feels when done.
KarlzEE Bebout 01-27-2024 07:57 PM
I drove a Cobra with a much quicker steering than my ERA 289FIA and I didn't like it at all. Of course, over time, I would have gotten used to it but I found that I tended to tweak the wheel a bit on hard shifts, and that made for a BAD feeling when the car wanted to twitch, rather than going straight. Justa thought. My 2¢
Grubby 01-28-2024 09:08 AM
For reference my 2012 Mustang GT is 2.25 turns lock to lock. It is a blast to drive.
John
DanEC 01-28-2024 03:04 PM
I had a 2012 Mustang GT for awhile. It was my favorite of 3 late Mustangs I had and the steering was fine.
DanEC 02-23-2024 06:12 AM
John, any progress on the quick steering. Genuinely curious but also wondering if the forum is taking posts any better.
Grubby 02-23-2024 10:55 AM
It turns out the pinion gear from the "custom" quick ratio rack was .125" longer on the gear end. I noticed when I was starting to assemble the unit. It is at my buddies house being turned. It wouldn't have taken much more effort to shorten while it was being resplined, but I didn't notice or expect FR to have done this.
I should have the final update this week.
John
