-   -   Hood prop rod (http://www.clubcobra.com/forums/era-speak-bob-putnam/17571-hood-prop-rod.html)
Melzer 06-03-2002 04:56 AM
Hood prop rod
Bob....
Can I buy a hood prop rod from you folks? The gas charged rods on my EM are shot......besides, I would rather have a OEM style rod for authenticity anyway.
thanks.....
Jim Holden 06-05-2002 02:57 PM
Suggest you call 860-224-0253 and ask for Bryan. He will try to signal Peter and get you an answer.
The rod itself is just a bent piece of... well... rod with a clip to hold it when not in use.
Morty MacTavish
Melzer 06-06-2002 04:28 AM
Jim....
I'll try calling Peter, Bob might be too busy catching up on other stuff.
Thanks...
Turk 06-06-2002 07:24 AM
Yes,
Bob is probably busy working on a three way switch for the radiator fan for me!
Call Peter, he is probably doing nothing. Maybe eating!
TURK
Bob Putnam 06-06-2002 08:47 AM
Turk,
It's a fairly major job changing the wiring to accommodate on-auto-off. Do you want to just stop the fan from running when the ignition is off? That's fairly easy.
Jim Holden 06-06-2002 12:18 PM
Bob:
Gee, the battery shut off switch works for me...
Get your butt back on the T-44 project...
Morty
Melzer 06-07-2002 08:29 AM
Turk...
Try using a bigger hamster on steroids to drive the fan, he will run much faster at higher speeds and slower at low speed ....thus giving the effect of a variable/auto fan setup. Much easier than the complicated wiring......besides, it will free up more of Bob's time for more important things, like my hood prop rod!! :D :D :D :3DSMILE:
Turk 06-07-2002 08:41 AM
Bob,
What I would like for the switch to do is.....
Position 1: It allows the fan to be controlled by the thermostatic switch like it does now.
Position 2: It Turns the fan off, like it does now.
Position 3:It shuts the fan off, regardless of the ignition position and the signal from the thermostatic switch. OFF period.
There is no urgency, just would like to be able to do that, to turn off the fan when it comes on after I have parked and few seconds later the fan kicks in.
TURK
