Old 04-26-2003, 04:10 PM
CobERA's Avatar
Cobra Make, Engine: ERA #644 428 FE
Question What size allen wrench for oil temp sending plug
Bob,
Do you happen to know what size allen wrench is needed to remove the plug from the top of a Canton Racing oil pan? I want to install the oil temp sending unit, but don't have any allen wrenches that big. As much as I would like to buy a whole set, since I bought the car I'm much more frugal (read "broke").
Just cause its so much fun, I've attached a picture.
ERA 644
I'm getting old too fast and smart too slow!
Old 04-26-2003, 07:21 PM
Rick, use a bolt with a head that will fit into the allen screw, with two nuts jammed together to take it out...or just grab the bolt with a vice-grip...cheap substitute for a big allen wrench.
Ken
Old 04-26-2003, 07:22 PM
Try the head on a 3/8 inch ratchett.
Difference of Opinion: Causes ugly women to marry and poor land to sell!
Old 04-26-2003, 07:39 PM
CobERA's Avatar
Ken/FakSnaks,
Thanks. Great (cheap) ideas. I'll give them a try.
Where were you today when I went and bought a crowfoot ratchet head to install my water temperature sensor?
ERA 644
Old 04-26-2003, 09:47 PM
Rick Parker's Avatar
It should take a 3/8" internal hex wrench.
Do it right........
Old 04-26-2003, 10:43 PM
I would say its 3/8' also. Go treat yourself as you will likely need the same size for plugs in the intake that won't be used.
I know your water temp sender will go in one of those holes.
You want big allen wrenches? Have a look at the one thats used on your adapters lugs should you have the Halibrand (read trigo) wheels.
I am assuming as you do have an ERA
Thats 12mm i think.
Tim
Old 04-26-2003, 10:53 PM
I would make sure you go ahead and get the right tool, because you will need it for the water temp plug, at least we did. We turned a 6 sided plug into a 12 sided plug (almost ), that's how snug it was in the manifold.
2500 Pounds of steel, rubber, and fire. AAAHHHH!
Old 04-27-2003, 10:04 AM
CobERA's Avatar
OK, I broke down and got a new hex key set.
The size is indeed 3/8".
I tried to be frugal - I really did.
ERA 644
Old 04-28-2003, 10:13 AM
Cobra Make, Engine: ERA, Ford 428 SCJ
Hey, that's what Credit Cards are for.
Of course, they do you no good when it comes to purchasing goodies from ERA........
Old 04-28-2003, 12:16 PM
CobERA's Avatar
Traveller - I think that is a good thing! They have gotten me in enough trouble already.
ERA 644
