December 2025
Old 06-19-2003, 01:20 AM
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Question Halfshaft Length?
Hi Bob,
I've got a newer XJS rear with outboard brakes. You folks shortened the lower control arm for me, but the axles are almost 1/8" shorter than normal, so I've got to shorten them myself. This wouldn't be a problem if I knew how long (short?) to make them. I talked with Doug at ERA, and he said you shorten the axles to 11 7/8". The print you sent me gives a center to center length of 11.660, which is .215 shorter. Please enlighten me.
Thanks,
Dan
Old 06-19-2003, 05:23 AM
Your axle should be shortened to the print I sent you. 11.66" c/c. Your different inner and outer components force the length change.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 06-19-2003, 12:52 PM
Cobra Make, Engine: ERA, Ford 428 SCJ
Grab the Sawzall!
Old 06-20-2003, 12:58 AM
Thank you, Bob.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
