-   -   Throwout Fork / Transmission Installation order (http://www.clubcobra.com/forums/era-speak-bob-putnam/55095-throwout-fork-transmission-installation-order.html)
joea 06-28-2004 10:13 AM
Can you put the clutch fork in after the trans is bolted up or does it have to go on before?
Also do you pull the clip on the fork all the way into the slot on the bellhousing or do you just insert the front of the clip?
strictlypersonl 06-28-2004 10:29 AM
The fork must be put in before the trans is bolted in.
The pivot "snaps" into the endentation of the fork, before it gets to the bulge of the retaining clip.
trularin 06-28-2004 11:09 AM
Engine plate, flywheel, clutch, pressure plate, bellhousing with fork and bearing in place and trans. In that order.
Clip all the way on and boot installed.
When everything lines up, the trans slides right in and the first bolt can be run in by hand. once all four bolts are in, you can move the fork to disengage the clutch. Check it before you lock anything down.
Had to remove mine three times on a clutch/pressure plate change.
Just my $0.02
joea 06-28-2004 11:11 AM
Thanks Bob
joea 06-28-2004 11:14 AM
trularin,
What boot are you referring to?
trularin 06-28-2004 12:43 PM
I have a rubber boot that mounts in the bellhousing that protects the opening from objects and junk getting in the bellhousing throught the clutch fork hole.
Don't you have one?
It's what I have.
joea 06-28-2004 01:00 PM
I dont....sounds like a good idea. perhaps I'll make one. On second thought making my own probably isn't the best idea
