-   -   Radiator (center tab) conversion (http://www.clubcobra.com/forums/era-speak-bob-putnam/58832-radiator-center-tab-conversion.html)
Melzer 11-14-2004 03:03 AM
Is it possible to convert this 'older' style top shroud mounted radiator to the center tab?
I need to be specific here and explain that the old brass radiator has already been updated to an aluminum 2 row 1-1/2" tube unit by Griffin. The Griffin unit is currently installed with the old style top shroud.
Radiator core dimensions are 21" x 19" x 3-1/4" as built by Griffin.
Photo attached
Thanks......
Mel
http://www.clubcobra.com/photopost/d...tor_small_.jpg
strictlypersonl 11-14-2004 03:53 AM
It shouldn't be much of a problem.
Our standard aluminum radiator uses 2 x 1.25" tubes so we'll have to make a custom top panel.
Installation Details
Melzer 11-14-2004 04:05 AM
Thanks for the quick reply....I'll stop in and see Peter to order the piece.
Mel
strictlypersonl 11-14-2004 10:09 AM
Mel,
We'll need the exact outside (front-to-back) measurement of the shallow U panel that's on the top of your radiator.
Melzer 11-17-2004 03:48 PM
Bob,
I'll be sure to get the front to back dimension of the panel......thanks for the heads up.
Mel
