-   -   Upper radiator hose options? (http://www.clubcobra.com/forums/era-speak-bob-putnam/59497-upper-radiator-hose-options.html)
cheesepocket 12-06-2004 09:02 AM
When I originally built ERA 469 I used a hose from the expansion tank to the radiator that is no longer available. I substituted in a similar one, but it is bigger in diameter and at the clamp ends and wants to rub on several things on its way. I have seen ERA cars with a 90 degree steel or aluminum tube, and just rubber clamped a the ends. Is this a tube I can buy from ERA, or where do you get it? Recommended hose PN's for the ends would be appreciated also.
3500 miles and still going strong!
Thanks.
strictlypersonl 12-06-2004 10:33 AM
The setup with the intermediate tube requires a radiator with a different upper hose fitting orientation. Our 90-degree connector would have to be shortened, and you'd still need a short angled hose to go to the radiator.
Gates 20819 will fit your car, and is currently available.
