Jag Outboard brakes
Hi Bob,
While I’m a loooong way from installing the outboard brake unit, I did check, and the 12” rotor assembly does fit in my 15” Compomotive wheels. The brakes use a 48mm single piston (sliding caliper); will I have to change my rear master cylinder, and if so, to what size? THANKS, Dan |
I believe the rear brakes are smaller than the large front brakes. Might check those in the wheels also!
Thanks anyway, and thank you, Bob. Dan |
Ohhhh! I see! Sorry:p
| All times are GMT -7. The time now is 07:29 PM. |
