-   -   Brake and suspension conversion (http://www.clubcobra.com/forums/era-speak-bob-putnam/78230-brake-suspension-conversion.html)
fordracer 04-16-2007 06:29 PM
Is it possible to convert a base model front brake system to the big brake option? If so, will the rotors work with the existing spindles or do they need to be swapped too?
Can the ERA rear suspension be swapped for the Jag rear?
If the answer to the above is yes, is there a certain cut off that it can't be done. Example, like the first 100 cars built.
Thanks.... :3DSMILE:
strictlypersonl 04-17-2007 04:01 AM
The big-brakes require a spindle swap before chassis ~650. The rotors are larger and come with hats. If you have bolt-on wheels, there's a new hub too. The pin-drive big-brake conversion comes with new pins.
The ERA rear requires (about 10 hours) welding on chassis before 565. It's a bolt-in on later cars.
fordracer 04-17-2007 09:36 AM
cool, thanks.... :D
