-   -   Wipers (http://www.clubcobra.com/forums/era-speak-bob-putnam/78826-wipers.html)
DonC 05-10-2007 07:30 AM
Wipers
Bob:
Have a minor problem with the windshield wipers on ERA684.
Initially the Low Speed position of the switch doesn't activate the wipers and I have to go to the High Speed position. While in High Speed position the wipers do not "park" when the switch is turned off, they just stop at whatever position they're in in the wiper arc.
After about 10 or 15 activations in a relatively short time (about 5 minutes) the Low speed position of the switch becomes active and the wipers park in the correct position from either High or Low speed.
Any ideas where I should start looking? Switch, relay board or motor?
DonC
strictlypersonl 05-10-2007 08:17 AM
The reason they don't park is that the power to park them comes from the low-speed circuit. So... the problem could be in either the motor (and internal park switch or the relay board. If you switch wires at the high speed and low speed terminals (at the motor), that will tell us a lot. There's also a wiper troubleshooting section (page 20) in my Wiring Primer.
DonC 05-11-2007 10:30 PM
Bob:
Once again the all knowing about things ERA. Thanks for the direction to go in my troubleshooting.
Thanks,
DonC
