fan not coming on
http://www.clubcobra.com/forums/era-speak-bob-putnam/89852-fan-not-coming.html)
| Godfather |
08-05-2008 09:31 PM |
fan not coming on
Bob,
I have the twin fans in front and the puller fan also. The twin fans come on at temp and also with manual switch on, my puller fan does not seem to be coming on. Should it also come on with the manual switch?
| strictlypersonl |
08-06-2008 04:04 AM |
The fans are all on the same circuit. The front fan jumper has a "Y" that bridges power to both front and rear systems. Try connecting the front harness plug directly to the rear fan. If the fan doesn't come on with the dash switch, your rear fan may be defective.
| patrickt |
08-06-2008 07:12 AM |
Here's what Bob's talking about. Try turning the dash switch on and then jiggling this connector by the radiator hose. Mine was defective and I ended up splicing around it. If jiggling doesn't fire it up, then switch them.
http://www.clubcobra.com/photopost/data/500/jiggle.jpg
| Jim Holden |
08-06-2008 08:05 AM |
Ah, the old jiggle solution...
Jim
| strictlypersonl |
08-06-2008 08:47 AM |
Jiggling is good.
Oh. You meant the plug connection...
| Jim Holden |
08-06-2008 09:08 AM |
That, too.
| Godfather |
08-06-2008 10:11 AM |
Thanks guys, I will check it tonight.
| patrickt |
08-06-2008 12:47 PM |
Originally Posted by Godfather
(Post 867580)
My money's on the "jiggle test" coming through to the rescue. Yes, I see the fan firing intermittently as GF jiggles....:LOL:
| Godfather |
08-07-2008 05:49 AM |
I Jiggled ( the plug not me) and you were right. After looking at the plug I can see the problem, it pushes the other spade out of the other side when connecting. I have it working now ,but think I will also replace with a different connection later. THanks for the help
| patrickt |
08-07-2008 06:23 AM |
(Post 867832)
The ol' jiggle test never fails. Bob, shall we split the fee based on my drive-by consult?:3DSMILE:
| Jim Holden |
08-07-2008 08:55 AM |
Before you invest in another connection type device, try to push the pin into the plastic connection. There are little "spurs" which will lock in (and require a small tube type device to unlock) if pushed in all the way.
Jim
PS There is no charge for my services, given gratuitously, one ERA owner to another.
| patrickt |
08-07-2008 09:09 AM |
I just cut, spliced, and soldered -- tossed the connector in the trash. It's a ten minute job.
| strictlypersonl |
08-07-2008 10:42 AM |
Originally Posted by Jim Holden
(Post 867885)
Jim
And your advice is worth every penny too. ;)
I think around chassis 600 we changed to a spade-type connector to the fans. No more pins. Although the male spades were also retained by a tang...
| Jim Holden |
08-07-2008 10:55 AM |
...and the females? How are they restrained?
J
Ya get what ya pay for...
| patrickt |
08-07-2008 11:11 AM |
(Post 867936)
J
Retained, not restrained.:rolleyes:
| Jim Holden |
08-07-2008 11:30 AM |
No, my experience with the females in my life is not to "retain them" but rather to "restrain them".
The choice of words was intentional, so roll your eyes back into your head.
Jim
Boy, first Cobras and now BDSM. Is this a web site or what? Pant, Pant.
DonC
| All times are GMT -7. The time now is 08:03 AM. |
